Pump Gas
Old Oct 24, 2007 | 04:30 PM
SSCUSTOM6.0's Avatar
Default Pump Gas
what is the highest you can go on compression and still be able to run only pump gas safely. 93 octane
Old Oct 24, 2007 | 08:38 PM
JSPERFORMANCE's Avatar
in the 11:1 area depending on the cam, gears, and vehicle weight, alot of factors go into detonation resistance.
Old Oct 24, 2007 | 11:02 PM
Websy21's Avatar
like above states, allot has to do with the cam but amny factors come in. I'd personally shoot for 11:1 with bigger chamber on the heads and a smaller gasket. Like stock 243 castings and .040 gasket for example.
