What else req. for 408
Old Oct 26, 2007 | 01:54 PM
lt1camaro95's Avatar
Default What else req. for 408
My LS1 is done and I am going to buy a 408 short block and put the stock LS1 heads on for now. Is there anything I would need to buy for a 408 swap? Is the harness different or I heard knock sensors are different. I searched the site but didnt see any real info of needed parts for the swap.
Old Oct 26, 2007 | 02:04 PM
slow trap's Avatar
no harness adapter necessary and you can reuse your knock sensors. i guess you probably already know this but the 408 will really be restricted with your stock heads. you going to go ahead and put in a decent sized cam for when you put on better heads ?
Old Oct 26, 2007 | 03:12 PM
I will put a decent cam in and hold off on the heads for a few months. A 408 isnt exactly a drop in the bucket.
Old Oct 26, 2007 | 03:16 PM
ls1leadfoot's Avatar
yea......330 flow at least on the heads and about a good 649 lift will make beautiful noise on the streets!!!haaahahah
good luck
Old Oct 26, 2007 | 10:41 PM
bump, bump
Old Oct 26, 2007 | 11:10 PM
Hennytime's Avatar
do the ls1 covers and everything swap over to the 6.0 block since they are both gen 3 motors? i mean cam retainer plants front and rear covers sensors valley covers, the works???
Old Oct 26, 2007 | 11:38 PM
Ericbigmac83's Avatar
Sounds like im in the same boat as you, im holding off on heads for now cause with heads you either gotta do a fast at the same time or the l92/l76 setup which adds up, but isnt too bad.
I did port my stock heads a hair though when i had them off, nothing drastic, but is should at least help with all that extra air coming in
Everything swaps right over, im in the middle of doing it right now, hopefully be done sunday
Old Oct 27, 2007 | 12:03 AM
Hennytime's Avatar
awesomeness. cant wait to graduate to do it
Old Oct 30, 2007 | 04:29 PM
Just finished getting mine in traction is officially a thing of the past
Old Oct 30, 2007 | 09:37 PM
mrr23's Avatar
if you are refering to the iron 6.0L blocks, everything will swap over. if you are refering to the aluminum LS2 block, then knock sensors and cam sensor are relocated.
