Cam Recommendations
What cam would make the most power mid-top range with a stock head/block. MAX RPM 6300-6400
Must also work with N20 and clear stock piston to valve clearance.
Bolt in cam, springs and push rods with no other modification.
Minimal tuning required.
Car has all the bolt ons and tube header dual 3" exhaust using 150 shot.
M6 4.56 gears will be running a 30" tire.
Sorry I meant work with the stock computer. Getting a tune on the chassis dyno isn't a big deal.
Just haven't used much LS1 stuff, all my old setups were carburated, so never had to worry about computer compatibility.
Was looking at:
Thunder Racing Custom Camshaft
"TR 224-112" - 224/224 .563/.563 112 LSA 1700-6600 RPM Power Band.
"Split Pattern" - 224/227 .563/.569 114 LSA For nitrous and supercharger applications. 2200-6800 RPM Power Band.
Was looking at:
Goals are Low 11's on a 150 shot.
Running a big tire because I like big tires. 315 60 15 isn't that big, I ran a 33x16.5 on my pro street car.
Budget would be for cam, spring kit and pushrods.
This is my fun car, I am just building it up over time, chassis wise it's a full blown drag style chassis.
I just want to make it a little more fun until I bite the bullet and start my turbo motor build up.
Not sure on cars weight, last time I weighed it was 3150, but since then i have removed the bumpers and mini tubbed it and pulled the power steering and redoing the carpet with light weight stuff.
I know I have taken out 100 pounds since then with the stuff I weighed.
Futral Motorsports HL F14 232/234 .646''/.612'' 112lsa+4 , good power under the curve and peak .
https://ls1tech.com/forums/dynamometer-results-comparisons/512050-new-f14-high-lift-cam-only-434-416-a.html
https://ls1tech.com/forums/dynamometer-results-comparisons/615147-f14-highlift-dart-225-heads-numbers-inside.html
The original F14 232/234 .598''/.598'' 112lsa+4 makes good power also .
http://lsx.streetfire.net/search/F14...6c6440a8ca.htm
http://lsx.streetfire.net/search/F14...b7015f0291.htm
Seen one car went 11.6 @ 116mph with the original F14 /Ls6 intake.. cam only , another run 11.30 @ 121mph with the HL F14 , Dart 225cc , LS6 intake .Both 6spd cars near full weight .
Heres another with Dart 205cc , https://ls1tech.com/forums/showthrea...light=Dart+205
Both will clear with room to spare as its only a 232/234@.050 duration .
Here another one with the F14 112lsa , stock 317 71.5cc heads , Fast 90 , Homebuilt D1-sc Procharger kit 13psi , Yank ss 4,000 stall , 3.73 gears https://ls1tech.com/forums/drag-racing-results/745228-stock-bottom-end-stock-4l60e-10-42-a.html
Peak lift is not a concern when talking p/v clearance , in example the Trex is on the ragged edge with 242/248 @.050 in a non flycutt piston . Its the duration and icl / ecl that matters . In a 360 degree rotation the Trex holds the valves open a longer period of time compared to the 232/234 @.050 F14 . Also the overlap period of which the exhuast valve is closing and the intake valve is opening at the same time is more with the Trex .
Trex is a great performer but needs the corresponding boltons in the car to complement it . Its a high rpm cam .
