Thick White Smoke at WOT
Old Oct 29, 2007 | 05:09 PM
lastcall190's Avatar
Maybe someone snuck a can of seafoam in there when you weren't looking...
...good to hear no ill effects have been had. Floor your car more!
-J
Old Oct 29, 2007 | 11:45 PM
flyin ryan's Avatar
Just keep a close eye on the coolant & oil levels.
If you do in fact have a problem you will see an noticeable drop in fluid levels.
Hope its all good.
Ryan
Old Oct 30, 2007 | 04:47 AM
vettenuts's Avatar
Another trick if you are burning coolant, pull the plugs. The one burning coolant will usually be much cleaner than the rest as will the top of the piston.
