LS1 block
Old Oct 28, 2007 | 07:02 PM
99mongooSS's Avatar
Default LS1 block
How much does machining typically cost on a 99 ls1 block?
Old Oct 28, 2007 | 09:21 PM
SS101's Avatar
Old Oct 29, 2007 | 10:22 AM
dmiz0420's Avatar
Inspection?
Honeing?
Boring?
Bearing installation?
Rotating assembly installation?
Balancing?
Old Oct 29, 2007 | 10:57 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Originally Posted by dmiz0420
Inspection?
Honeing?
Boring?
Balancing?
Agreed, you need to be a bit more specific. It all depends on the job and the shop that does the work.
Old Oct 29, 2007 | 02:50 PM
blueeyeddevil141's Avatar
Hahaha, alot. Striping, hot tanking, honeing with a deckplate, second hot tank boil, cam bearings, hot tanking new pistons and reassemble them to rods, boil rods, measure pistons, glass bead pistons, scotch bright the skirts, puff honeing them, final washing the pistons, hot tanking the crank, measuring crank, magnaflux the crank, polishing the crank, and boiling the crank. As well as balancing the crank cost me $1500 bucks.
Old Dec 9, 2007 | 09:28 AM
hotrod44_4u's Avatar
Whats The Cost Of A Used Ls6 Bare Block?whats The Cost Of A Used Short Block And What Included In A Short Block?
