ASA cam installed! got a few questions
Just installed GM's asa cam in my 99 TA 6 spd
along w/ granatelli maf. Car has stock heads,LS1 intake, and manifolds. It searches for idle but does not ever die. The car bucks hard under 2k in 1st but i expected that. I had gutted cats before and had a ses light but after the cam install there is no ses light and the car smells really rich. I need tuning now and long tubes, right now i have the exhaust off where the y goes into the single pipe. Also when i turn on the a/c the car seems to settle into a better idle and lope, Can i idle it up like this by the bump stop screw? The cam sounds awesome, lopes hard and pulls like mad, I would like to just get that constant lope idle like when the a/c is on. Thanks
. the only thing i can think of causing the problem is running it lean and burning the pistons. just some advise. i now 3 guys who never tune theres and run stock injectors with 6000+ miles already with no problem (lucky SOB's)
oh well i bet it sounds bad *** mine DID
