Uh Oh, Too Much Compression?
Old Oct 30, 2007 | 07:30 PM
00Formula00's Avatar
Default Uh Oh, Too Much Compression?
HELP!!!!
So I am about set to order the new cam/trans./gears/flycutting stuff and then I come across this thread O NO.... https://ls1tech.com/forums/generation-iii-internal-engine/806151-milling-205-afr-s.html
So I am reading along I see post #16 talking 59cc AFR 205's (which I have) and someone using a cometic .040 gasket (which I was going to run). He says that the compression on that would be 11.83-SCR which as I now understand is in the zone of requiring a much higher octane gas? Also, he wrote that 59cc is .042 milling and I have heard from most other places that it is .030. Someone with knowledge could you fill me in... I'm really hoping I catch a break on this one.......
-Rob
Old Oct 30, 2007 | 07:32 PM
02blackbeauty19's Avatar
I dont think the CR is usually that high. I think its more in the 11.3-4 range.
I could be wrong, but I think im right
Old Oct 30, 2007 | 07:36 PM
I was thinking the same thing, I have done lots of research about these heads and I have never seen a number that high before...
Old Oct 30, 2007 | 07:42 PM
10SecDreamer's Avatar
Maybe .042 milling if you are refrence to 241's and .030 to 243's?
241= 67cc; 243= 64cc
To my specs Im running 11.9:1 on 93, so far no knock retard but I forget how much timing I have.
Old Oct 30, 2007 | 07:47 PM
In Cali. it's really hard to find 93 and if we do you have to give the gas station an arm and a leg for it...Basically, I will only be running 91, unless I find myself somewhere close to a race track
Old Oct 30, 2007 | 07:54 PM
jub jub's Avatar
On AFR heads, a flat cut @ .006" = 1cc. I have .036" cut from mine for a 59cc combustion chamber. I would have no problem running .045" Cometics with a nice quench and 11.5 to 1 compression ratio.
Old Oct 30, 2007 | 07:57 PM
jub jub, running pump gas?
Old Oct 30, 2007 | 08:19 PM
ExceSSive's Avatar
I was running 62cc with .045 gaskets and ~11.3, more importantly where is your dynamic compression?
Old Oct 30, 2007 | 08:40 PM
JScamaro's Avatar
With a .040 gasket and 59cc heads I think that would be too much compression for 91 octane.
Old Oct 30, 2007 | 08:42 PM
I have no clue where mine is, I am yet to do a compression check...in that thread he said it would be 8.87 DCR
Old Oct 30, 2007 | 09:11 PM
DONAIMIAN's Avatar
Im gona be right at 8.86 and im in texas with decent gas. Im using every anti detonation trick in the book. I would try to get yours to around 8.5-8.6 to be on the safe side.
Old Oct 30, 2007 | 09:13 PM
DaveX's Avatar
DCR is what you need to look at, not just SCR. Obviously the cam is a big part of the equation. 8.87 is slightly more than I shoot for with 93 octane, but if your not getting any KR then all is good. I think 8.6 - 8.7 is ideal. The higher you can get away with the more torque you will have, all things being equal.
Old Oct 30, 2007 | 09:32 PM
So the thing is all this talk is with the cometic gasket right? I think I am going to use the GM MLS gasket, rather than the cometic, I would much rather lose a few ponies and have a motor that wont blow
Old Oct 30, 2007 | 09:43 PM
ExceSSive's Avatar
mine blew...#7 piston...booom!
Old Oct 30, 2007 | 10:08 PM
DaveX's Avatar
You can get cometics in different thicknesses. If you want to lower your DCR a little, recalculate it with .045 and .050 gaskets to see what you need to put it where you want to be.
Old Oct 30, 2007 | 10:37 PM
jee wizz so what does that leave me to do? I ran this setup for about 7,000 miles before the trans shot with out any engine problems....
Old Oct 30, 2007 | 11:45 PM
99blancoSS's Avatar
I'm calculating a scr of 11.8:1 and a dcr of 9.09:1
If you have to advance your cam any that will increase the dcr even more.
Wrong!! Mamo spec' ed my stuff 59cc 11.3:1 .040 cometic, no issue what so ever on 91 octane. My car runs great we have the worst gas in the country in Oregon.
Old Oct 30, 2007 | 11:47 PM
99blancoSS's Avatar
Theres nothing wrong with your setup. Call Tony Mamo next week when SEMA is over and ask him. He knows AFR's better than anyone else, dont be panic'ed. I run the same head at 59cc. Different cam but if thats all you need to do then your fine
Old Oct 31, 2007 | 12:23 AM
not to be gay but I love you BlancoSS, you just made my week... I'll hit Tony next week just to make sure
Old Oct 31, 2007 | 12:40 AM
Prerun4fun13's Avatar
Hmmm interesting
