Uh Oh, Too Much Compression?
Old Oct 31, 2007 | 05:21 AM
DaveX's Avatar
Originally Posted by 00Formula00
jee wizz so what does that leave me to do? I ran this setup for about 7,000 miles before the trans shot with out any engine problems....
I think your on the edge but if your not having any problems I would leave it alone. Do you have scanning capabilities to see if you are getting KR? If it is too high for the gas you are running it will show up with knock retard.
Old Oct 31, 2007 | 01:42 PM
00Formula00's Avatar
I don't have a scanning tool but I had the car tuned with this set-up, I will be switching to the GM MLS gasket and flycutting my pistons soon anyways so I should lose some compression there... But as for knocking, I'm not sure... After the tune my tuner said there was a little ping, so he took out timing? and it went right away
Old Oct 31, 2007 | 02:59 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
They start out at 66cc so 66 - 59 = 7cc of material removed. It takes about .007 milling to removed 1cc from a traditional LS1 head. So 7cc x .007 = .049.
Speed inc has this option for AFR heads on their website:
Flat mill cylinder heads .020" (66 cc to 62.5cc)
66 - 62.5 = 3.5cc and they say it's a .020 mill so:
.020 / 3.5cc = 0.0057142857142857142857142857142857 mill / cc
That's assuming their information is correct.
Take that info and:
0.0057142857142857142857142857142857 mill x 7cc of material removed = 0.04 mill exactly.
Or you could simply take their .020 number for -3.5cc of material and double that because 66 - 59 = 7cc. I just wanted to figure out how much material needed to be removed per cc.
.020 x 2 = .040
Originally Posted by ExceSSive
I was running 62cc with .045 gaskets and ~11.3, more importantly where is your dynamic compression?
Finally someone said the right thing. Your static compression ratio aka the 11.x:1 number doesn't really mean **** when you're talking about gasoline limits. You have to use your DCR numbers for that. Here's a really nice DCR calculator Piano Prodigy did: https://ls1tech.com/forums/generation-iii-internal-engine/630637-my-dcr-calculator-if-you-have-comp-grind-doesn-t-get-any-easier-than.html
Originally Posted by 99blancoSS
Wrong!! Mamo spec' ed my stuff 59cc 11.3:1 .040 cometic, no issue what so ever on 91 octane. My car runs great we have the worst gas in the country in Oregon.
Useless!! You have a forged shortblock with vavle reliefs. Not an apple to apple comparison.
Old Oct 31, 2007 | 03:04 PM
^^ nice post ^^
The thing is that I am not going to run the cometic gasket, I will be running the thicker GM gasket and also I will be flycutting my pistons .080 only on the exhaust-- If what I have been reading is correct both of those things should drop some compression from my engine right?
ALSO, I have been running the same chamber heads with the cometic gasket and a 224 cam and I have had no problems... I don't understand why I have to worry? Will the new cam (X3) effect my compression
Old Oct 31, 2007 | 04:19 PM
Asmodeus's Avatar
^^ nice post ^^
Not your static compression, but it will effect your dynamic compression.
Old Oct 31, 2007 | 05:33 PM
hammertime's Avatar
Please do your self a favor and look for the G5x3 vs. MS3 Thread.
Post # 23 explains why you may not need to flycut with the G5X3 cam (but you still need to check!). Also, if you haven't had detonation problems to date with your smaller 224 cam, then you shouldn't have any problems with the X3, due to its later Intake Valve Closing. As a matter of fact, thicker head gaskets reduce the activity (known as squish) in the chamber, and can increase the risk of detonation. If the are sealing well, leave them on and check clearance with cheacking springs and a dial indicator to see if it clears.
After all, Louis himself says it will.
Hi guys, there is 220 thou of valve drop with a milled, 59cc AFR and .040 cometics.
There is 200 thou of valve drop on a stock motor.
Any X series( G5, X1, X2, X3, X4, 111/112/114 excluding the xX ( which in most cases, thats install only here at the shop) will fit on a stock engine, 112 or 114. The X3 110 will not clear stock heads, but it will be close on the AFRs. You gain quite a bit of PTV with AFRs. If you are not sure, and want to know what your setup came in at, check it.
I wish that thread had been stickied, 'cause I know I've directed a dozen people to it since I've been here.
Good Luck!
Old Nov 1, 2007 | 11:09 AM
Prerun4fun13's Avatar
Good Luck!
So let me get this straight... Louis from LGM is saying that we do not have to flycut when using a AFR 205 59cc head with the G5X3 on a 112 or a 114 LSA. I would like to know because i will be helping Rob (00formula00) install this cam and it would make life a little easier not having to fly cut. Before we cut should we clay the pistons and check PTV first. Or is it a deffinite fact that we have to flycut?????
Old Nov 1, 2007 | 11:10 AM
Also Rob we can get a scan tool to check if you are having any knock retard..
Old Nov 1, 2007 | 11:54 AM
I talked to Lou a little while ago and he told me that it would fit, but it is a definite that nothing will happen if you flycut (obviously)...
Old Nov 1, 2007 | 07:13 PM
OWN3D BY MY PROF!
^^ nice post ^^
Thanks,
Like said above running the cometics reduces squish and helps quench aka good things. What thickness are yours now? If they are still in good condition reuse them and save some money over buying new GM MLS ones.
Do you already have the cam you plan on running? If not I'd talk to Patrick G or Predator Z about designing a custom cam for your application. I also wouldn't be scared of flycutting. Yes, it's more work, but it'll be worth the extra power. With flycutting you can run a larger cam with a tighter LSA. You can also run thinner headgaskets that will help control detonation.
Actually it effects both.
I wouldn't take anyone's word on doing something so important. It's worth it to check it out. You might do something wrong like install the timing chain one tooth off or something like that. It's always a good idea to check PtV clearance.
Old Nov 1, 2007 | 08:40 PM
Asmodeus's Avatar
He asked, "Will the new cam (X3) effect my compression".
No. changing just a cam will not alter your static compression at all. That's what I was answering.
Old Nov 2, 2007 | 10:56 AM
  #32
yum, complicated stuff here...
Old Nov 2, 2007 | 11:16 AM
  #33
OWN3D BY MY PROF!
I read that incorrectly. I thought he was asking if fly cutting the pistons would affect compression.
Old Nov 2, 2007 | 01:43 PM
  #34
hammertime's Avatar
If you read the post, Louis says that all of the X series cams, even the X4 on a 111 LSA, clear the stock setup. It also states there is more clearance with the AFR 205 heads after milling than stock unmilled heads. With the existing setup, you should be fine.
That said, it is too easy to check & ensure it clears. Every engine is different, and a stock bottom end does not always push the pistons .007 out of the hole. Instead of pulling the heads to clay the valves, which can sometimes give a false reading, use a checking spring. This way, if you have clearance, you don't need to R&R the heads, clean the head bolt holes, etc. Here is what I suggest - take it for what it's worth:
  • get the X3 cam if that's what you want
  • pull the valve covers, remove the rockers and pushrods
  • remove front engine dress and pull the cam
  • install X3 cam, timing set & a degree wheel
  • install checking springs (low tension coils) on the #1 intake and exhaust valves
  • install adjustable length pushrod adjusted to the proper length - lifter preload (0.060" - 0.100")
  • install a rocker arm on the intake valve and place a dial indicator on valve side of the rocker arm
  • slowly turn the engine over to about 90* before TDC on the exhaust stroke (not compression)
Here's where you find out hom much clearance you have. As you turn the engine towards TDC, a few degrees at a time, keep pressing the top of the retainer down gently about an 1/4", feeling for it to contact the piston. You probably won't get near it until 30* BTDC or so. Once you make contact, begin checking every 2-3 degrees by zeroing the dial indicator against the spring tension, then measuring the distance you can depress the valve until it touches the piston. The procedure should be pretty much the same on the exhaust side.
Someone please correct the above if I've missed anything or made any errors.
Old Nov 2, 2007 | 07:36 PM
  #35
Thimble's Avatar
I'd love to know how he arrived at that number...unless you are running dished pistons.
59cc + .040 gasket, minus 1cc missing from my pistons = 11.67 SCR.
Without piston reliefs, ~11.8 sounds about right.
As I recall it, Tony's favorite formula always took the heads down to 61cc for ideal compression.
LG started taking them to 59cc, mainly to compensate for the 2cc they were flycutting out of the pistons for use with their bigger cams.
I have the X4 cam, so my DCR is a little lower than what it would be with the X3. At 11.67 SCR, and 8.77 DCR , I'm fine on 93 octane. Have not tried 91.
The DCR will be a little higher though for an X3 cam, so yeah I think that setup is probably too much for 91.
Old Nov 3, 2007 | 10:36 AM
  #36
So, I am running a thicker fel pro gasket right now and everything fine, I run California91 and there is no ping/knock so what I don't understand is how if everything is of now, why would it change if I run the same gasket and flycut?
Old Nov 3, 2007 | 12:28 PM
  #37
hammertime's Avatar
I used PianoProdigy's DCR calculator to come up with the following.
Assuming you are running .053 thick head gaskets, 59cc chambers, no valve reliefs, and a 224 duration cam on 110 ICL (IDK Thunders Lobes specs, but I used an XE-R to approximate them). It gives a SCR of 11.43, an IVC of 42* ABDC, and a scary high 8.96 DCR that should rattle that thing to death on 91 octane.
If you change nothing but the cam, the X3 grind has a 234* intake lobe on a 112 LSA and a 108 ICL. That moves your IVC to 45* ABDC, and drops the DCR to a more reasonable 8.73 - without any valve reliefs. While it may be marginal for 91 octane, it should be less likely to detonate with the larger cam than the smaller one.
I would be curious what your heads CC at for you to not have detonation issues with the TR224 cam you are running now.
Old Nov 4, 2007 | 12:55 PM
  #38
That's wierd because I have been running this setup for a while now, no knock, no detonation???
