timing chain question
Old Nov 1, 2007 | 06:27 PM
orangefun's Avatar
Default timing chain question
I am getting ready for a cam swap (car has 60k) and I just bought a ls2 timing chain, and I was wondering how many of you swap a new chain but use the old sprokets???
Old Nov 1, 2007 | 07:52 PM
litle88's Avatar
I used the old sprockets, no problem. Just check to see how they look!
if the sprockets look really worn then change them too!I think they are only like 30 bux. remember to always upgrade.
Old Nov 1, 2007 | 08:25 PM
Thorny's Avatar
I just put in a new chain without changing the sprockets. The old ones looked good as new.
Old Nov 1, 2007 | 11:05 PM
Daryn's Avatar
Formerly darynC-10/23/10
i got the comp cams adjustable and left the bottom sprocket . just used the chain and cam sprocket works good!!
Old Nov 1, 2007 | 11:14 PM
ABQ99TA's Avatar
I used the old sprockets and I know a few if my friends that have done the same with no issues.
Old Nov 1, 2007 | 11:34 PM
massls1guy's Avatar
I just bought the LS2 chain before I started the swap. When I got in there the cam sprocket had 2 cracks so I got the newer LS2 style sprocket from the dealer. Might as well get a new cam retainer plate while you're in there - it comes with a new gasket. If you get the plate make sure you get the new bolts that go with it, wider bolt heads.
Old Nov 1, 2007 | 11:50 PM
chromeplated500's Avatar
i vote use existing sprockets.... at least give 'em a once over while your doin it.
Old Nov 1, 2007 | 11:53 PM
Ericbigmac83's Avatar
old sprockets looked just fine on mine when i threw on a ls2 chain
Old Nov 2, 2007 | 09:50 AM
Blacker's Avatar
Unless any of the teeth is broke, just reuse the sprockets with the LS2 chain.
