lq4 question
Old Nov 3, 2007 | 02:39 PM
ls1leadfoot's Avatar
Question lq4 question
i have a buddy with a 6.0 lq4 with about 60,000 mi on it...only wants 600 for long block......will i have any problems getting all my ls1 parts onto this block and will it bolt right up.......
and can anyone tell me the perks of lq4 block vs ls1 block
just need some reassurance before i go through with this deal
and yes the motor is decent looking doesnt look like crap
Old Nov 3, 2007 | 04:20 PM
fenix999's Avatar
all parts should be completely interchangeable, gotta make sure the compression is what you want because the LQ4 come with a "dish" lower compression piston. So yea that would be the only thing to keep in mind really. Other than that the only upside is that its iron, its "stronger", but the downside is that its about 88 pounds heavier than the 5.7 block so you get a few cubic inches and some strength but add weight to the front of the car. hope this helps
Old Nov 5, 2007 | 07:13 AM
thank you......now heres another question....since i have a lq4 block what parts to i search for.......ls1 6.0ltr or 01 2500hd 6.0 lol
yes i was shocked when i found the dish pistons.......power adder time haha
Old Nov 5, 2007 | 08:38 AM
does anyone know the specs on the lq4
piston diameter
rod length
crank
stock cam
??.......any info
Old Nov 5, 2007 | 08:58 AM
408z28's Avatar
The lq4 has a 4.0 inch bore, the same stroke as the ls1 (3.62), and the same rod as the ls1. The only difference between it and your ls1 Is the bore, and the fact that its made out of iron. Everything will interchange. When you order parts just say you have a ls1...less confusion.
Old Nov 5, 2007 | 09:23 AM
ah hah......so order for a stock block and bore ls1
Old Nov 5, 2007 | 09:32 AM
teke184's Avatar
what "stuff" are you trying to order??
the bore is different...so ordering pistons for an ls1 won't work if you're putting them in the lq4
Old Nov 5, 2007 | 09:42 AM
69LT1Bird's Avatar
Also, since the LQ4 pistons are dished 6.7cc's you may want to put in LS2 or LQ9 flat top pistons to get the compression ratio up. Like the previous post said, LS1 pistons won't work.
Old Nov 5, 2007 | 09:55 AM
69LT1Bird's Avatar
One more thing, there is a change in the LQ4 engines. Depending on the year, they made a piston/rod change. The went from fixed to floating pin. You need to have t correct info if you order pistons.
Old Nov 5, 2007 | 10:31 AM
yeah i can tell its a floater.....i am getting ready to have it tanked and jet blasted, then hoaned on wednesday....the shop sd there is only a 3 day turn time.....haha
thats quick.......gonna let the pistons soak in kerosene to get the **** out of the rings and stuff.......then time for ms3 and tons of bolt on-s
any other ideas or suggestions while the engine is stripped and out of the car
Old Nov 5, 2007 | 12:25 PM
408z28's Avatar
You have to order the pistons for whatever bore size you are running. I thought you were talking about headers/intakes/ etc. external parts. Stroke and rod length will be the same....Pistons will be 4.00 or whatever you bore the block to.
Old Nov 5, 2007 | 12:36 PM
i want to see how the pistons clean up then i will explore the options for the bottom end.....i dont want to buy pistons or rods untill they are needed.....the 6.0 will be stronger than the stock ls1 ne ways
Old Nov 5, 2007 | 02:23 PM
talked to texas speed......sd that with that dish on the pistons in the lq4 i would be roughly at 9.1.1 comp with a .040 gasket and 10.1.1 with a .030 gasket.....and safely run a decent shot of spray......with the 10.1.1 would be the safest bet
what do you think???>...
