Jeep Wrangler conversion.....HELP!!
Old Nov 3, 2007 | 03:07 PM
utijeeper's Avatar
Default Jeep Wrangler conversion.....HELP!!
I am in the process of my conversion with a 2005 5.3L (i know its not an LS! but its farily close lol) and 4L65E into my 97 jeep wrangler. Last night i took off the spark plug wire at the coil on the rear right hand side coil (#8 i think) to access my CTS (for my gauge) and like a dumb A** I forgot to hook it back up and i was running it to bleed my cooling system and power steering and i noticed that it wouldn't rev up and it was acting funny so then i heard sparking and i was looking around and i noticed it arcing to the exhust manifold. I shut her down and hooked it back up and it is still running like crap....I think i may have fried that coil but would it run that crappy on 7 cyl.?? Or did i wipe out my PCM or ignition control modual??
Old Nov 3, 2007 | 03:17 PM
NoGamesLS1's Avatar
Feel the header (be carefull) or hit it with a infrared temp gun. Make sure all your wires are connected properly. Also ohm out each wire with a volt meter. Ive had issues with bad wires before. Good luck
Old Nov 3, 2007 | 04:24 PM
LS1MCSS's Avatar
It probably just got crap on the plug, since it wasn't firing for a while. Try pulling that plug and cleaning it.
