No Oil Pressure!!!!
Thanks,
Adam
Do a search; look for same problem in a thread last week...
A guy put in a re-built motor but no oil pressure. There are two possible sources:
The freeze plug-type things are missing from the block; they take these out when cleaning the block but not all builders replace them!!!!!
1. One is in back of the motor between the tranny and engine block ...under the flywheel...
2. The other is under the cam retaining plate...
If you had some but not enough oil pressure the likely problem is an oil pump o-ring on the oil puck up tube; If you have NO oil pressure, however, the o-ring is not the problem....
Read the earlier posts since this is just what I recall...
In fact many here have reported running their engines for months with no oil pump o-ring. ...it ussually gets pushed into the pump where it is chewed up by the pump gears.
pressure is ussually in the 20Lbs or so with no -o-ring.... normal is 40lbs or so...
...if it is, you probably missing the freeze plug thing in the rear case under the flywheel...
I suppose the pump and not the pump -o-ring could be bad...
maybe the pump gears were left out when they assembled the unit...
I doubt it, but a real possiblity I suppose...
How do you know no oil is getting to the pump? Did your old pump have pump gears?
Did you read the other post on NO OIL PRESSURE?
They seem to point to no freeze plugs (1 under cam retainer and one under flywheel) as the likely culprets????
...but I thought you said you just re-built the motor...I assumed you are working with a new oil pump, NO???
Did the second new pump solve the problem?
