Head gasket availability
Old Jun 16, 2003 | 12:41 PM
silent1's Avatar
Default Head gasket availability
I'm looking for some head gaskets to fit a 4.030" bore but haven't had any luck finding them. Does anyone know where I could find some? Someone suggested getting 6.0 head gaskets(4.000" bore) and have a machine shop open them to a 4.030" bore, is this safe to do? Thanks for any help.
Old Jun 16, 2003 | 01:07 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Head gasket availability
I'd check out Cometic head gaskets.
Are you NA or FI? What compression?
Old Jun 16, 2003 | 01:53 PM
robertbartsch's Avatar
..Mr Gasket has some special ones too.
Old Jun 16, 2003 | 02:26 PM
silent1's Avatar
11:1 CR and N/A, thanks for the help. I thought comoetics were frounded on?
Old Jun 16, 2003 | 08:07 PM
OSR 1's Avatar
call the shop I stock all bore sizes
Old Jun 17, 2003 | 03:08 AM
malibu350's Avatar
I believe the problem with the cometics is using them on the earlier style heads that have the notch in them...they cause coolant to leak out where the notch is.
