LS1 Heads
Old Nov 6, 2007 | 04:37 PM
Grifter's Avatar
I bought my car with ported stock heads and a small cam(.222/.222) I am very impressed with the power it made and it's on stock injectors. I am waiting to install my 30# and make a little more power.
Old Nov 6, 2007 | 05:03 PM
cdoggy81's Avatar
What do stock 241's flow vs. stock 243's?
Old Nov 6, 2007 | 07:01 PM
Azrael's Avatar
http://ourworld.cs.com/jrp98ls1/stockheadflow.jpg
LIFT - 241 | -LS6
.050 _33.8 | _33.0
.100 _63.6 | _65.2
.150 _96.7 | 100.7
.200 135.2 | 138.0
.250 166.3 | 167.7
.300 191.0 | 192.7
.350 210.4 | 213.1
.400 223.2 | 230.0
.450 230.3 | 243.1
.500 226.5 | 254.1
.550 226.5 | 257.0
.600 230.6 | 238.0
.650 234.6 | 240.1
.700 237.8 | 242.3
Old Nov 6, 2007 | 07:08 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Moving to Internal.
Old Nov 6, 2007 | 08:37 PM
cdoggy81's Avatar
Thanks Azrael!
Old Jun 7, 2013 | 07:16 AM
handyandy496's Avatar
now somebody put up some ported numbers of each! just for fun.
Old Jun 7, 2013 | 08:04 AM
td1168's Avatar
IMO for the money you will spend on getting your heads ported and the other machine work done along with valves and springs you might as well spend a little more money and buy a set of heads already done and set up. I bought the PRC Stage 2.5 5.3L CNC Ported Heads from TSP for $1400.00 and bolted them on my engine. These may not work if you're running stock pistons with a big cam but my point is that you're better off buying a set of heads already done . I've heard good things about the patriots too!
Old Jun 7, 2013 | 11:38 AM
PREDATOR-Z's Avatar
Not all porting programs are created equal. Meaning that ported X brand will be different than same casting ported in another shop.
