ls6 cam in ls1 worth it?
Old Nov 5, 2007 | 01:01 AM
ApexVIII's Avatar
Default ls6 cam in ls1 worth it?
is it worth it to put a ls6 cam in a ls1? can you keep the stock ls1 springs?
Old Nov 5, 2007 | 01:03 AM
93redBIRDman's Avatar
not worth it. There are waaaay better cams that will make a lot more power...
Old Nov 5, 2007 | 01:04 AM
didnt see the 2nd part of your question, if you went with an ls6 cam you cannot keep your stock LS1 springs. ANY aftermarket cam needs better springs than the stockers. You can pickup come LS6 yellow springs for cheap on this board, under $100. I've seen them even go for $60 on here...
Old Nov 5, 2007 | 01:05 AM
ApexVIII's Avatar
lol thats what i figured. ok
Old Nov 5, 2007 | 02:13 AM
gts500's Avatar
not worth it man.... if drivebelty is what you lookin for go for slightly bigger cams like MTI or any wide LSA cams it will give you way much better performance than the LS6.
Old Nov 5, 2007 | 03:33 AM
PREDATOR-Z's Avatar
LPE GT2-3 is better if you are into that power range, durable, stealth, yet capable of 400 rwhp + with the right combo.
Old Nov 5, 2007 | 08:22 AM
johnLs1camaro's Avatar
if your looking for a good daily driver cam with a little more power and sound id say do the gm hot cam but id even go bigger
Old Nov 5, 2007 | 11:23 AM
litle88's Avatar
+1 for the hotcam!
I got one with the mods on my SIG(click it for videos)
with a stock ls6 intake I put down 393hp and 370tq!!
Then I got a fast 90 witha UMI TB and pit down 406hp and 378tq.
No Tb issues no problems driving, awesome lil cam.
Old Nov 5, 2007 | 11:24 AM
litle88's Avatar
ps I got my Ls6 springs from texaspeed really cheap! call them.
Old Nov 5, 2007 | 02:39 PM
ApexVIII's Avatar
what cams will pass the CA sniffer? i know that the CheaTR cam will, is there any other more powerfull ones?
Old Nov 5, 2007 | 07:15 PM
1Bad00SS's Avatar
A friend put down 406 with the ls6 cam/ls6 head package, unported heads and intake. Drives like stock.
I've got a 220/224 camshaft with .563 lift on a 117lsa.. would fit your criteria. Pm me if interested.
Old Nov 5, 2007 | 09:19 PM
ApexVIII's Avatar
what cams can pass ca smog?
Old Nov 5, 2007 | 10:08 PM
Blk97WS6's Avatar
Any of the cams listed above should pass. If you need to pass the sniffer i wouldnt go any bigger then maybe a 224/224 on a 114 lsa without talking to your tuner first.
Old Nov 5, 2007 | 10:38 PM
Evans752's Avatar
I use to run the LS6 cam and have put several in stock motor cars LS1 Camaros and Trans Ams. I went 11.91 on drag radials with stock 241 (LS1) heads and 3.73 gears in my )1998 Camaro 6 speed and they say run 7.425 pushrods or 7.45 pushrods and I tryed both and ended up running 7.40 (stock) pushrods. and the reason they say to do this is the valves in the LS6 heads are a hair longer. I also always put Comp Cams 918 springs with stock retainers on them and raise the rev limiter to 6500 RPM and pull a little timing out. I had a lot of fun with it but it was time to upgrade. LOL Good Luck
Old Nov 5, 2007 | 11:29 PM
BayAreaSS's Avatar
The ls6 is a waste of time. Just get a 224 on a 114 if you're worried about passing smog.
Old Feb 13, 2008 | 03:29 PM
badinfluenceRS's Avatar
Does anyone have any numbers for a LS6 cam/springs/pushrods in a LS1? (LS1 heads/intake)
Old Feb 13, 2008 | 03:46 PM
King Nothing's Avatar
whats smog? hahahahha
Old Feb 13, 2008 | 04:18 PM
5_02ls1's Avatar
ill sell you my cam and springs cheaper than you can buy it new less than 500 mi cheap
pm me if interested
Old Feb 13, 2008 | 04:22 PM
5_02ls1's Avatar
oh and its alot better than an ls6 cam
Old Feb 13, 2008 | 06:04 PM
01 BERGER CAMARO SS's Avatar
I you want performance and money is an issue, jus get the LS6 but it its not. Jus go with Predator-Z cam or and MTI steath cam 1 or 2 will be good also. Either way, I would up grade the springs on any cam swap.
