ls6 cam in ls1 worth it?
Old Feb 15, 2008 | 07:43 AM
LS698ta's Avatar
you can easily reach 400rwhp on a ls6 cam and boltons with a set of ported stockers or a set of ls6 heads
Old Feb 15, 2008 | 07:44 AM
LS698ta's Avatar
plus the ls6 cam loves nitrous
Old Feb 15, 2008 | 01:18 PM
DANOZ28's Avatar
i have it, wish i'd gone slightly bigger. 550 lift, 218/204 duration, 117 lsa. yes you need bigger springs to run this cam! positives are no lope (stealth) ,smooth idle 600 / 700 rpm. drives like stock. negatives, low dyno numbers for all the work unless your trying to pass emissions go bigger. the board here likes tr224. i called lunati and they recommended 560 lift, 221 dur on 115 lsa for what i wanted. SLP has a 560 lift 214/222 dur cam , TPIS has zl11 about 560 lift 215/220 dur . its a tuff choice, good luck.
Old Feb 8, 2017 | 12:30 AM
Noah Murphy's Avatar
Originally Posted by johnLs1camaro
if your looking for a good daily driver cam with a little more power and sound id say do the gm hot cam but id even go bigger
this hot cam is it the ls1 hot cam?
Old Feb 8, 2017 | 04:24 AM
King Nothing's Avatar
Yes it is
