Which will gain the most? TR 227/224 112LSA or C2 cam?
I was looking at the TR 230/224 cam and was told that i would have to spin the motor to 6700rpms to get the full power range from this cam and i don't want to get any higher than 6400 rpms because of my 80K bottom end. The tech at Thunder suggested the 227/224 112LSA with mine being a A4 to get the power band down to 6400,where my B1 cam is and said i should see about a tenth gain in the 1/4 over my B1. I'm thinking i can make the TR 230 work but im not positive with mine being a A4 and shift points set at 6400 rpms.
What about the C2 cam from MTI? It looks like a cam i had picked out before but i don't see alot of talk about it? This is a future project for later in the year but i would like to get a cam set when i have the money to order,as long as another cam does not come along between now and then lol
Scott
Scott
Hey Scott sounds like You are getting ready for some low low 11sec passes.I hear that the X1 cam is a mean one. Goodluck!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Secret](https://ls1tech.com/forums/images/smilies3/secret2.gif)
They're all good cams and you can advance them a little and stay with the smaller LSA's to get the power band down. A lot of people have the C2; I think 224 duration cams are the best compromise for a daily driver. I picked the TR224 over the C2 because the extra lift of the C2 seemed excessive to me since I'll be staying with stock heads for quite a while and don't want to beat up my springs too bad.
