Old May 18, 2016, 06:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
JPR lifter tool?
Old Nov 16, 2007 | 05:07 AM
DMONEY06's Avatar
Default JPR lifter tool?
how long are the shafts on the jrp lifter tool?? can i use some small rods same length dont really wanna pay 125 for a tool im prolly going to use once
Old Nov 16, 2007 | 07:55 AM
radkon's Avatar
Yes you can use either wooden dowels or aluminum dowels to do the same thing.
5/16” or ¼” rods approx 26”
Old Nov 16, 2007 | 09:02 AM
99blancoSS's Avatar
Or you can rent them and a few other specialty tools from me like so many others have done. PM me
Old Nov 16, 2007 | 03:44 PM
Xtnct00WS6's Avatar
Just go to Home Depot and buy some metal rods and cut them to length.
Old Nov 16, 2007 | 03:56 PM
Prerun4fun13's Avatar
JRP tool is a waste of money!!!!!! Just buy 5/16" wooden or metal dowels, i used wood it was easier to cut.
http://i1.tinypic.com/85og3k6.jpg
http://i19.tinypic.com/8biu1wh.jpg
those are pics from my cam install..
Old Nov 16, 2007 | 05:37 PM
davered00ss's Avatar
Moderator
I can measure mine later, but they are about 20" long.
Old Nov 17, 2007 | 11:34 AM
eallanboggs's Avatar
I bought the JPR tool years ago, but have found it doesn't work on all LS series engines. When I have trouble removing a cam with the JPR tool installed I use a 5/16" metal rods(unthreaded) @$5 each from Home Depot. If you haven't bought the JPR tooll as yet stay away from it and get the meatal rods. I'd shy away from wooden dowel because the rods are pretty hard to remove on certain engines and I'd worry about getting wood out, but steel or aluminum is going to come out even if you have to pull on it with a lot of force.
Old Nov 17, 2007 | 01:48 PM
99blancoSS's Avatar
They served me and a bunch of my customers very well thank you.
Old Nov 19, 2007 | 12:53 PM
radkon's Avatar
If you go with metal rods make sure to coat them with motor oil
Old Nov 19, 2007 | 03:24 PM
DMONEY06's Avatar
thnx for all the info
Old Jan 17, 2008 | 02:39 PM
caleBot's Avatar
My motor is out of the car on a motor stand. Can I just turn the motor upside down (to prevent the lifters from falling) while I'm doing the cam swap?
Old Jan 17, 2008 | 08:34 PM
slammed1500's Avatar
i was thinking the same thing
can some body answer this 4 us??
Old Jan 17, 2008 | 08:37 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Yes, you can invert the engine and remove the risk of a lifter falling down. However, my concern is that any trash/metal bits/etc. that has migrated to the bottom of the oil pan (or elsewhere) will drizzle toward the valvetrain and other places where it doesn't belong.
Steve
Old Jan 17, 2008 | 08:48 PM
o damn i already had the motor upside down
i cant get the damn 5/16 rods 2 slide in the passange side dont go in at all and the drivers i can only get it in about 2 or 3 lifters and it stops
