224/224 112lsa
Old Nov 16, 2007 | 05:42 AM
CarnivorWS.6-01's Avatar
Default 224/224 112lsa
Is there anyone of the cams (manafacture) that is better than the rest or should I base my purchase on reputation and price (value) This is the cam I will be buying just don't know from who. Need honest feedback.
Old Nov 16, 2007 | 06:18 AM
BIG_MIKE2005's Avatar
Just either order one from TSP or TR & be done with it. I believe both will be ground by Comp anyway.
Old Nov 16, 2007 | 07:54 AM
radkon's Avatar
While they are both ground by Comp TR has proprietary lobes (I don't believe anyone else is "allowed" to use their lobe design). That being said the two are within a few HP of each other and neither is a "bad" choice. I LOVE my TR224!
Old Nov 16, 2007 | 11:12 AM
Ryan02SS's Avatar
As stated Comp grinds both TSP and TR's 224's. The TR lobe is propietary and is a tad less aggressive than the XER lobe.
Old Nov 16, 2007 | 05:40 PM
davered00ss's Avatar
Moderator
TR224 is a well proven cam. TR = Thunder Racing ------------>
Old Nov 16, 2007 | 08:23 PM
hammertime's Avatar
If you are going to go mail order, you probably have the two best recommendations already.
If you are looking to buy local, check and see which of the board sponsors is closest to you. You may be better off looking to see what kind of package deals they offer, and whether they can dyno tune the car (afterall, they should know their package better than anyone else).
Old Nov 16, 2007 | 08:31 PM
99 BLACKFIRE's Avatar
I have a Comp 224 with 581 lift unlike the 563 that the TR224 has. Sounds nice and pulls hard. I am happy with it.
Old Nov 20, 2007 | 10:51 PM
noah89's Avatar
Check out Speed Inc.'s Comp 224/224. I made 385 rwhp through a 12 bolt and 4.11's. It's very nicely mannered on the street and makes decent power.
Old Nov 20, 2007 | 11:48 PM
Soul TKR's Avatar
from what you guys are saying...
who makes the 224/224 114lsa grind?
Old Nov 21, 2007 | 10:39 AM
It's not gonna be the 224/224 or the 114LSA that will be the difference. It's in the lift numbers. The .581 & .563 cams are are ground different. I believe it's the .581 cam thats ground on the EXR lobes which are more aggressive & have a higher ramp rate.
Someone correct me if I'm wrong.
Old Nov 21, 2007 | 11:03 AM
hammertime's Avatar
IIRC - the rate is pretty close to the same between the TR lobes and the XE-R lobes, which is why they do make good power.
Fact is, you really can't go wrong with either one. I'd be surprised if you could quantify the difference between the two of them without a back to back engine dyno. Even at that what is .018" lift?
Old Nov 21, 2007 | 11:05 AM
quick346's Avatar
I ran the comp promag 1.75 rocker's on the tr224 and had .580 lift. my car is a auto and with the afr's 1st gear was worthless at any speed with street tire's.
Old Nov 21, 2007 | 12:56 PM
BriancWS6's Avatar
The XE-R lobes are more aggressive than the lobes used in the TR cam. Both are good cams, but I would go with the XE-R grind personally.
Old Nov 21, 2007 | 01:45 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Id go with the TR224.....
Old Nov 21, 2007 | 02:05 PM
TheLS1Kid's Avatar
Either way you will be pleased.
Old Nov 21, 2007 | 02:15 PM
AU N EGL's Avatar
224/228 .581/.581 112 lsa XE-R comp cam here
Love it
Old Nov 21, 2007 | 03:45 PM
Moderator
Do a search on the TR224. It will out preform the others.
