cam specialist i need help...thanks
Old Nov 19, 2007 | 06:04 PM
firefighting1101's Avatar
Default cam specialist i need help...thanks
ok heres the deal. i am thinking of going cam only for now and later getting a set of heads. my current setup is as follows: volant intake, typhoon intake manifold with 85mm tb, egr deleted. pace setter coated long tubes, tsp true duals, and i have a nitrous outlet 85mm plate kit that im running 100shot now. i want to get a cam with a good amount of torque, and builds power at relatively low rpm's. the car is an everyday driver so i would like it to be relatively driveable aswell...lol if anyone has any thoughts please let me know. i will also be replacing the springs, retainers, pushrods, oil pump and timing chain at the same time. o and adding a fuel pump very soon.
one more thing. my car is a 98 and i have a set of used 2000 heads. should i have those cleaned up and install those instead? please help me out guys. thanks a lot.
Old Nov 19, 2007 | 06:07 PM
o and i forgot to mention my car is m6 and i have a good tuner as soon as the job is done.
Old Nov 19, 2007 | 06:27 PM
is it ok if i just pm patrick g?
