springs/retainers for tr224
Old Nov 20, 2007 | 11:46 AM
food nd cars's Avatar
Default springs/retainers for tr224
What would be the right springs and retainers for a tr224? would Patriot Gold "extreme" spring kit do? Ive got a basically stock SS right now. Planning to do shorties (Cali Smog) and Y w/ high flow cats. What else do i need for a tr224 swap? Also should i do the headers/y pipe first or cam first?
Old Nov 20, 2007 | 11:48 AM
sroach20's Avatar
regular patriots would work. dont forget to do an ls2 tiiming chain and an ls6 pump.
Old Nov 20, 2007 | 11:49 AM
blackmaro99's Avatar
Get your exhaust work done first.
In the mean time, run a search on the tr224 and you'll get all the info you need. Or just call Thunder Racing.
Old Nov 20, 2007 | 12:25 PM
SSpdDmon's Avatar
Comp 918s are usually fine for a 224 cam. But, if you want the added safety of a double spring, the Patriot Golds (.650 lift) would work as well.
Old Nov 20, 2007 | 07:41 PM
Do i "need" a new timing chain and oil pump?
Old Nov 20, 2007 | 08:10 PM
sroach20's Avatar
its up to you, you dont have to.
Old Nov 20, 2007 | 10:14 PM
noah89's Avatar
The cars all ripped down for the cam. There's really no charge to install the chain and only a few bucks to do the pump. Cheap insurance if you ask me.
Old Nov 20, 2007 | 10:17 PM
Tainted's Avatar
do the cam last
simple comp 918 springs are more than suffiecent
Old Nov 20, 2007 | 10:18 PM
sroach20's Avatar
i guess the question should be, how many miles on the engine?
Old Nov 20, 2007 | 10:55 PM
cdoggy81's Avatar
Where is the cheapest place to get a LS6 oil pump & LS2 timing chain?
Old Nov 20, 2007 | 11:02 PM
Tainted's Avatar
texas-speed.com
Get the oil pump and a new chain. its cheap insurance.
Old Nov 20, 2007 | 11:18 PM
Ok its a 2000 SS M6 w/ 55,xxx miles. Lid, cut out, some other small stuff. Thing is that money is tight and i want to get the most out of my dollar, but still make a reliable set up. btw it is my dd.
Old Nov 21, 2007 | 12:38 AM
Tainted's Avatar
you need all of your supporting mods before you go throwing in a cam. do some searching, the answers are all there
Old Nov 21, 2007 | 04:00 AM
SOM 02's Avatar
well if your gonna run the 918s i have some. its the springs,lock,seals and something else. not sure the miles on them but the look good. if your gonna run them let me know. i will let them go for 110 shipped
