AFR / LS6 Heads ?
Have fun!
Can you elaborate on the setup: Headers, Intake, exhaust system and EXACT cam specs; LSA lobe type and lift etc ...
tilly
The car you saw did not have a FAST 90 setup
It likely did not have the electric water pump
We don't know what headers or exhaust it ran - LG has the best system by far for a C5 or C6
Since the tuner did not build the car, there is likely less motivation to tweak the tune to the extent Tony has
We don't know what it dyno'd before mods
We don't know exact cam spec's, or if the heads were milled at all
All of that said, something is likely still wrong with car. Relativly stock Z06 cars are usually putting 345 to 360 to the wheels, so the exhaust, cam and tuning alone should have cleared the results you posted.
Again, I'm not debating the numbers you saw, rather the extent to which that car was prepped in comparison to Tony's.
2002 Firehawk
402 LS1 Iron block | MTI Stage 3R | M6 12 bolt | QTP 1 7/8 HVMC
QTP Timing Cover & OIL PUMP | East Side Tuned 523RWHP/497RWTQ
From your signature, we can infer Ken tuned your car to some rather solid numbers. I'm sure he tuned the Z06 to the best of his ability, but that doesn't address any of a dozen other possibilities - some I mentioned, but many more I didn't. It's hard to make any judgement without all of the facts.
Its the AFR 205 milled fresh from afr to 62cc
AFR 224/228 cam
7.4 Trickflow pushrods
Cometic headgaskets 045 thickness i believe
ARP headbolts.
I want 2500 for everything plus shipping.
Its back home in philly, and i won't be down till Dec 22nd for two weeks and then i can ship them out then so i don't need payment right now, but ill hold the stuff for you or anyone else till i get down there and then we can figure it out.
2002 Firehawk
Wrong and wrong again....
There are numerous cars with AFR 205's and our 224/228 stick (the "Mamo cam" as people like to refer to it), that are making low/mid 400's to the ground without every bolt on that helped my very optimized (and legitimate) set-up make 470-481 RWHP on a half a dozen different dyno's in two States. It averaged about 475 on a decent day....a little better or a little worse depending on who's dyno and weather conditions at the time.
The car/dyno you witnessed (briefly) was obviously not a very good copy....admitidly it didnt have a ported 90/90 (thats 25 by itself)....were the heads milled, thinner gasket used, EWP, UD, cam degreed in, perfect exhaust system (LG Pro at the time), good CAI, optimized timing and fuel.....etc, etc.
You get my point....
Tony
PS....There are a few cars (independent real world builds) within striking distance of my numbers that copied my package almost to the letter. One was an A4 car with a higher stall converter that put down 440....thats an easy 460-470 with an M6.
Remember is you cant afford the answer you shouldnt be in the game... lol!!
2002 Z06 [11sec club]
Torch Red/Mod Red; Vara-Ram; P&P TB; 160*T-stat; Kooks LT's w/ catted X-pipe; BB TriFlo PRT exhaust; Hurst Ripper; 403rwhp/390rwtq
We all have an agenda here. Tony's is to sell his product, a damn good one that a lot of people have run to good success.
Mine is to find the best bang for my buck because I know I'll never be able to afford a 402 with monster heads and all the required upgrades to make it work. There are a lot of good choices out there, but I've thoroughly researched what is available, and AFR 205's consistently deliver the goods. Since I know I can't afford to do it twice, I'll feel better spending my money on the product that gives guaranteed results. I'm here to share my observations with other members of the forum because they've asked for the input. I'm judging the results you've provided because they fly in the face of conventional wisdom, and there has to be good reason why.
You are entitled to not care why that setup didn't work, but I don't think its fair to the community to let one set of poor results like those speak for an otherwise proved setup. Even without the EWP and FAST 90, an otherwise properly prepared M6 car should hit 430-440rwhp.
I have a 03 LS6 with TPIS LTs, looking to change to LGs, TPIS TB and my own air box
I currently have LS6 heads and have some LPE SWGT heads sitting in a box weighting for a cam choice, But I am not dead set on the SWGT heads as they love high RPMs Plus I have an ofter to sell them too.
TIA
Tom
Tony
