blue smoke on decel?
Old Nov 22, 2007 | 01:24 PM
noxiouSS's Avatar
Default blue smoke on decel?
Did a few dyno runs and on the 2nd and 3rd run the car gave off a little plume of bluish smoke after letting of the gas at around 6300. Never smokes any other time. Is this from the valve seals?
Old Nov 22, 2007 | 01:30 PM
hammertime's Avatar
Have you modified your PCV?
High rpm & no load are known to cause oil consumption.
Old Nov 22, 2007 | 01:36 PM
noxiouSS's Avatar
no. I have put an ls6 intake on it. Should i put a catch can in?
Old Nov 22, 2007 | 01:58 PM
hammertime's Avatar
Has your car been using oil at any other time? Driving style has quite a bit to do with it, again high rpm, no load conditions.
If the answer is yes, then perhaps you should consider it. Oil in the combustion chamber can lead to additional carbon deposits, and the potential for hot spots and detonation as they accumulate.
Old Nov 22, 2007 | 02:13 PM
noxiouSS's Avatar
nope. It only smokes on the dyno decel. I raced it the day before at the track and there was no smoke at all.
