The age long question: 5.3 vs LS6 for my setup...
on stock cubes your not going to get a much better budget head out of the box!
i think the stage 2 ls6 heads would be way overkill for your setup.
those are generally used on bigger displacement motors
If you're comparing 2 heads with the same or very similar flow numbers, always go with the one with the smallest ports for the best low end, mid range, driveability, and in most cases the most hp. The only downside to the 5.3 is there is less piston to valve clearance, but you should be fine with the cam you already have. Just don't run a thinner head gasket without flycutting.
Jason
I sure as hell can't.
I don't want a set-up that pulls hard at 4000+. I'd rather have something that pulls pretty strong through as much of the range as possible.
