Cleaning the deck..?
Old Nov 23, 2007 | 12:29 AM
LS1Silverado05's Avatar
Default Cleaning the deck..?
Whats the best method or tool for cleaning the deck surface before replacing the heads? I assume there is a "best" way since its aluminum? Something to put on a drill maybe?..
Old Nov 23, 2007 | 12:46 AM
Evans752's Avatar
I buy some plastic type buffing pads off of the Snap On truck is what I have always used. Other places might sell them (Napa,Autozone,Advanced Auto Parts) but I dont know for sure. Hope this helps. Good Luck
Old Nov 23, 2007 | 01:19 AM
Tainted's Avatar
i used one of those lil rubber nub wheels you put on a drill to clean mine but everyone said that it wasnt a good idea.
It got clean, and it feels smooth so who knows?
Old Nov 23, 2007 | 01:56 AM
rubber nub wheels?...I dont know if I know them or not..
Old Nov 23, 2007 | 03:45 AM
LS1MCSS's Avatar
Scotchbrite pads are what a lot of people use. I used them on mine and it works good.
Old Nov 23, 2007 | 07:13 AM
eallanboggs's Avatar
Single edge razor blade in one hand and vacuum cleaner nozzle in the other. You can finish with Scotchbrite.
Old Nov 23, 2007 | 08:57 AM
AutomagicLS1's Avatar
A small razor blade and get a gallon of acetone at the hardware store. That stuff will take just about anything off and clean the deck real good once you get the crap off
Old Nov 23, 2007 | 10:20 AM
vettenuts's Avatar
Bamboo chopstick shaped like a chisel (won't scratch aluminum) and scotchbrite pad with de-natured alcohol. No metal of any type for cleaning.
Old Nov 23, 2007 | 10:36 AM
Marc 85Z28's Avatar
Use a 3M Bristle Disc: http://solutions.3m.com/wps/portal/3...beGS5N3GC52Hgl Use a conditioned new razor blade with brake cleaner to remove the bulk of the gasket, and the 3M disc to remove the rest.
The use of regular Roloc discs or Scotch Brite pads introduces way too much debris into the engine. ALL major engine remanufacturers (including the OEMs) warn against using them, and any evidence of using them voids the engine warranty.
Old Nov 23, 2007 | 11:01 AM
BlackScreaminMachine's Avatar
Internet Mechanic
For 01 heads.
stuff rags in the lifter valley holes
Scraper for the heavey stuff
Scotch Brite Pad with Wd-40 for cleaning the surface
Brake clean
Air hose or a vaccume to clear the bolt holes.
Final prep and wipe with brake clean and rag (clean)
Old Nov 23, 2007 | 05:17 PM
DaveX's Avatar
I would stay away from power tools with aluminum. I used a razor blade and just took my time. Just go slow and don't let it dig in.
Old Nov 23, 2007 | 05:34 PM
BriancWS6's Avatar
I used an ice scraper that you would use on your windshield. It's plastic, so it couldn't hurt the aluminum, but it was sharp enough to peel away the gunk. Worked nicely.
Old Nov 23, 2007 | 06:08 PM
HAMRHEAD's Avatar
Scotchbrite pad here. Worked fine.
Old Nov 23, 2007 | 07:46 PM
Tri5Nerd's Avatar
Scotbrite,acetone and scrubbing. Be patient because it's going to take some time to get it clean. Don't forget to clean up the pistons also if they have any carbon buildup.
Old Nov 23, 2007 | 09:17 PM
Good tip. Should I use TB cleaner or what?..
Old Nov 23, 2007 | 11:50 PM
BigBirdTA's Avatar
Actually I've tried all of the above. The best and fastest results I got were with scraper and then a razor.
The trick is to lubricate/dissolve with GM Top End cleaner or Seafoam. They are solvents that will dissolve as you scrape. Once done with the scraper, there's so little left that a razor will take it off in a hurry.
Old Nov 24, 2007 | 02:57 PM
blkbird's Avatar
I used the scrapper and razor blade method myself.... Worked pretty good.
