Forged Bottom End
Old Nov 25, 2007 | 08:03 PM
jeremy02's Avatar
Default Forged Bottom End
What all does it take to forge the bottom end of your motor? What price range can I expect if I decide to do it?
Old Nov 25, 2007 | 08:07 PM
platinum1's Avatar
what are your goals first off?
Old Nov 25, 2007 | 08:29 PM
TS6's Avatar
TS6
WTF is a "Gorillaz chip" (in your sig)? Please tell me you didn't buy a chip for your 2000 F body....
Anyway, forged shortblocks with stock cranks can usually be purchased for around $3K from a few different sponsors.
Old Nov 25, 2007 | 08:32 PM
jeremy02's Avatar
It's basically a 30 dollar resistor, but it's gone now and I was retarded.
I don't want to buy a new block, I want to buy the stuff to forge my block.
My goals are: Dont bend anything, don't crack anything, don't blow anything up.
Old Nov 25, 2007 | 08:35 PM
RooRnZ28's Avatar
are you looking for stock cubes? power goals? also, you have an sts kit, right? there is more than one way to skin a cat (or build a motor)
Old Nov 25, 2007 | 08:41 PM
platinum1's Avatar
Callies Crank, Compstar Rods,wiseco Pistons.= Done
Old Nov 25, 2007 | 08:53 PM
TS6's Avatar
TS6
Overkill? Stock crank is plenty.
Old Nov 25, 2007 | 08:54 PM
TS6's Avatar
TS6
Heres a bit of advice:
Say you buy a set of rods, pistons, bearings, etc. Then you have the machine work done and maybe the bottom end professionally assembled. You'd be money ahead to buy a pre built short block and sell yours.
Old Nov 25, 2007 | 09:24 PM
Speed's Avatar
I've seen a stock crank, diamond pistons, and forged rods put down nearly 1000hp to the tires. If you are looking in the 700-800hp range on a good tune and race gas, a forged rotating assembly in a stock block will do well.
Old Nov 25, 2007 | 09:33 PM
platinum1's Avatar
true, i am just going based on the f1r lsx setup i am starting to build
Old Nov 25, 2007 | 10:04 PM
SSilverSSurfer's Avatar
**** even the eagle rods hold up plenty. unless youre trying to run 7's.
i kept the stock crank(had erik get it polished, etc.) eagle rods, Wiseco pistons, Wiseco rings, coated bearings, ARP main studs.
Old Nov 25, 2007 | 10:25 PM
jeremy02's Avatar
If I get rods and pistons, do I need anything else supporting?
I'm not looking for big numbers. Highest I'll probably ever go is around 500 HP on an STS kit(until I get money for a rear end). How much am I looking at spending on rods, pistons, and installation?
Old Nov 25, 2007 | 11:45 PM
BriancWS6's Avatar
Only 500 hp? I would leave the stock internals in there at that power level with no worries.
Old Nov 26, 2007 | 12:03 AM
Soul TKR's Avatar
Here's my thread on forging my bottom end... it might provide a little info for ya
https://ls1tech.com/forums/showthrea...46#post8095546
Old Nov 26, 2007 | 01:11 AM
HAMRHEAD's Avatar
I wouldn't forge the shortblock for 500hp. I would put the money elsewhere to support the FI and put it to the ground.
