Comp valve spring question
Old Nov 25, 2007 | 08:43 PM
RE AND CHERYL's Avatar
Default Comp valve spring question
My current set up includes a MTI Stealth II cam w/.581 lift and stock heads with Comp 915 springs. This winter the engine comes out for a new clutch, stage 2 5.3l ported heads, and LT headers.
My question is, I got the heads with no springs on them and since they seem to be doing fine on the stock heads and only have a few k on them, I was thinking about transfering them to the ported heads. Any body got an opinion on if they are adaquate for my new set up or should I go for a better spring. Typically the motor dosn't get run too hard, rev limiter is set at 6200 RPM, and I might goto the track maybe once a year. It's main task is as a DD.
Re'
Old Nov 25, 2007 | 09:33 PM
bigdsz's Avatar
The 915's are light springs that will float with a decent sized cam, I'm surprised you haven't had any with your current cam. I ran the 915's about 6 years ago with a small cam, but when I went to a TR 224 I had float with them.TSP duals for <$300 are great.
Old Nov 25, 2007 | 10:09 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Comp cam has now Re-designed 918's gun metal grey, can handle .625" lift and better pressure loads, many companies have been using them with great success.
Old Nov 25, 2007 | 10:15 PM
Any way to know if I'm getting the old or new 918 spring design.
Re'
Old Nov 26, 2007 | 05:35 AM
vettenuts's Avatar
I would get the PAC 1518's if you are going to swap. They are an endurance spring and have surface treatments for longer life. The use of the 915's, if they are OK now, will likely be a function of the valve weight in the new setup vs. the old. You may be able to just buy titanium retainers (if you don't have them already) and continue to use the springs.
Old Nov 26, 2007 | 05:42 AM
nesikachad's Avatar
921's a bad choice then?
Old Nov 26, 2007 | 05:51 AM
kirby's hawk's Avatar
Re'
Comp Cams did a recall on the old 918's. so all 918's should be the new design.
Old Nov 26, 2007 | 10:34 AM
mvvette97's Avatar
Patriot Golds all the way. $250 . Never a single spring for me again,,
Old Nov 26, 2007 | 11:05 AM
Internet Mechanic
Re'
I had old sets of 918's and they were DARk, almost black and they had a Blue slash down the side for the 2 sets I did owned, these are completely gunmetal in color.
Old Nov 26, 2007 | 11:27 AM
bigdsz's Avatar
If you have the $$$ the 921's are the best, however if you're on a budget the TSP springs and titanium retainers are the way to go.
Old Nov 26, 2007 | 01:21 PM
I am on a budget of sorts. I also know the motor is not run real hard and rearely sees above 5500 RPM (maybe this is the reason I havent had problems with the 915s I have now). I was leaning toward 918s or other beehive type springs because they will work with the stock retainers.
Re'
Old Nov 26, 2007 | 04:04 PM
mrhzk35404's Avatar
Old Nov 26, 2007 | 05:52 PM
vettenuts's Avatar
The PAC 1218's are the old Comp 918's. Someone has them on sale right now too.
Old Nov 27, 2007 | 06:37 PM
Last C5's Avatar
Herron Performance has both the 1218s and the 1518s on sale.
