What are the torque spec's on the bell housing bolts?
I just did a cam swap, During the cam swap I dropped a lifter in my engine so I had to drop the oil pan far enough to reach in with a pen magnet to retreive the lifter.
to do this I had to loosen the two bottom bell housing bolts, I was wondering what are the torque spec's on the two bottom bell housing bolts?
Thanx in advance.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Man that sucks
sorry to hear that... did you already have the heads off or is that another sore subject
Well to answer your question it should be 35 ft/lbs (I just looked it up on ls1howto.com)
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
