ARP MAIN STUD questions ?
Old Dec 4, 2007 | 04:19 AM
Guacamayo's Avatar
Longer studs go in the center and shorter ones go on the outer part, torque is 60 lb ft on the longer ones and 50 lb ft on the shorter ones, good luck
Old Dec 4, 2007 | 05:45 AM
LSx007's Avatar
**** .. i didnt wanna deal with it .. so i just sent them back to the shop and got in store credit ..
i sat and really tought ... im probably not gonna make 800 whp .. maybe but not..
theres alot of people that have made alot more power so i should be fine .
i will soon built a lsx block for boost .. ill use the studs then and make sure i give the machine shopthem bofore its al put together ...
i wish i knew what would have happend if i just put them in .. but too much money would have gone down the drain if sumthing would have gone wrong .. better safe than sorry ... studs on the next build ..
thanks to all ...
