LS1 Fuel pump question......
Old Dec 1, 2007 | 12:58 PM
kokamo's Avatar
Default LS1 Fuel pump question......
Hey guys, I have a few questions to pick you brains with. I'll try to be as straitforward as I can..........
1. Does the LS1 (99) have a fuel pressure regulator? I don't see a return line to the tank.
2. There is somthing on the drivers side fuel rail that looks like a regulator, but it dosent have a return line coming off of it. What is it?
3. Finally, what is the reccomended fuel pressure ration on a stock LS1 engine?
Thanks for any help, please pe patient as I am somewhat new to the LS1.
Joe
Old Dec 1, 2007 | 01:04 PM
sroach20's Avatar
returnless fuel system, regulator is on pump assembly. 380-410 kPa (55-60 psi)
Old Dec 1, 2007 | 01:09 PM
bczee's Avatar
1) The intank pump and regulator, that is why there is only one line running from tank to engine.
2) That is a surge valve. Helps keep the fuel pressure steady.
3) 58psi is the recommended pressure.
Old Dec 1, 2007 | 01:18 PM
kokamo's Avatar
Thank you very much guys.
Just the info I was looking for.
MUCHO-GRABBASS!!!!
Joe
