should i buy a new cam?
my car is setup as my sig states, but i just bought a set of PRC Stage 2.5 heads from a member on here. i know my current cam will work just fine and probably set me over the 450rwhp mark with these heads, but i was just curious if i should swap cams "while i'm in there."
any of you cam guru's have any suggestions? maybe for a custom grind? thanks...
I think your cam looks like a good one but I would figure up the dcr and make a decision based on that. Also it would depend on what lobes your current cam has.
i'm not sure what lobes it has it's Speed Inc.'s SI5 cam. i have the card and either i'm looking at the wrong parts or it doesn't show which lobes it has. it's on a 110* ICL. it says it's Comp's grind #3725R / 3728R HR112+2...if that helps any...
I think your fine with what you have. Although you sig says 417 RWHP and you trapped only 111 with a M6? Have you had that looked into? Or maybe you just a bad driver LOL JK bro. Seriously, with 417 ponies and a M6 you should be trapping at least 115ish. I hit 116 with 381 ponies. Just a thought bro. That is a very, very good 60' though. Which also makes the 111 seem weird to me.......
