guyz with 408 strokers
Old Dec 2, 2007 | 12:51 AM
xdanny510x's Avatar
Default guyz with 408 strokers
people with 408strokers
what cam and what stall are yall running
or what cam do yall recommend
Old Dec 2, 2007 | 11:09 AM
BigBirdTA's Avatar
TSP MS3 or MS4. MS4 lifts higher & has higher powerband. Both need upgraded valve springs, and you might want to also consider stronger rocker arms & lifters, better oil pump & timing chain.
Both will need tuning.
Old Dec 2, 2007 | 02:57 PM
NOZR1's Avatar
I'm running a 244/248 .612"/.615" 113 lsa with a 4000 stall.
Old Dec 2, 2007 | 06:54 PM
bigdsz's Avatar
Comp XER 244/248 .612/.615 112+2
Old Dec 2, 2007 | 08:53 PM
Rowin Gearz's Avatar
T-REX here...242/248 608/612 on a 110 LSA. Through a M6 with a 4.10 geared 12 bolt. Never been to the track...just a result of wretched excess. Loads of fun...scares anyone within 1/2 mile when fired
Old Dec 2, 2007 | 09:26 PM
santiago's Avatar
im an m6....and running 257/266 110 lsa
Old Dec 2, 2007 | 10:02 PM
King Kong indeed!
Old Dec 2, 2007 | 11:15 PM
SOM 02's Avatar
same cam as this idiot
Old Dec 2, 2007 | 11:21 PM
1badA3Z's Avatar
I had the tsp giant cam in mine,and had a th400 with a 4k stahl,if u want any details just shoot me a pm,goodluck!
Old Dec 3, 2007 | 01:50 AM
xdanny510x's Avatar
well imma be puttin this 408 in my truck with l92 heads l92 manifold so thats why im tryna get an idea if i should go wit a bigger cam than listed in my mods
Old Dec 3, 2007 | 05:13 AM
SOM 02's Avatar
yes your gonna wanna get a new cam. that cam is way to small for a 408. u should talk to someone and have them spec you out a cam. it all depends on what you want outta your setup. but a 224 cam is not gonna be good in a 408
Old Dec 3, 2007 | 05:29 AM
GET_SOM's Avatar
How much did you all spend on your builds when it was all said and done?
Old Dec 3, 2007 | 07:22 AM
408z28's Avatar
I ran a texas giant...with 3500 (nitrous stall) made killer torque.
Old Dec 3, 2007 | 08:29 AM
Rhino79's Avatar
I would let Patrick G spec you out one. You have to take into consideration the weight of the vehicle, converter size, and engine specs like compression, flow numbers for the heads etc. What are your goals with it?? Those are all things Patrick G takes into consideration. Well worth $25 for him to hook you up.
Old Dec 3, 2007 | 08:35 AM
Randy_S's Avatar
Same cam here all built and spec'd by Eric and HKE.
Old Dec 3, 2007 | 08:42 AM
2001 Pewter WS6's Avatar
Restricted User
That was the combo I ran when I had the A4. I had 4.11 gears also...
Old Dec 3, 2007 | 08:48 AM
santiago's Avatar
$4150 for built shortblock,cam,and double roller chain.
1100 for budget heads
2500 for miscellaneous bullshit
labor was free cuz we did the work in my driveway
Old Dec 3, 2007 | 09:33 AM
kickassT/A's Avatar
248 254 .615 .601 lsa 112. spec'd by Erik @ HKE
Old Dec 3, 2007 | 09:43 AM
xdanny510x's Avatar
well i quoted close to 6500
3700 for a 408
2200 for the Cylinder Head and Manifold Package, SLP/L92 Drive by Wire (64cc)
.. well my goals is to basically due a killer street truck.. and to see some strip in the summer. the guy said expect 530 rwhp on all motor and then i told him bout the nitrous kit i got and he said safley u can run a 200 shot ..and another goal is to run either a procharger o a sts turbo my mid late summer
Old Dec 3, 2007 | 01:05 PM
SS DNA's Avatar
Talking
You guys are running some huge cams there....
Im glad you guys got everything done already..Last time I was there you guys were waiting for the heads I believe.
Hows your friend doing with the white Z28 ?
