Advantage to higher ratio rockers?
It'd probably be best to call Patriot Performance and see what they recommend... I know w/my TR224 higher than stock ratios aren't recommended due to the ramp speeds of the cam...
Figure if a cam is advertised as .560 lift that means that the actual cam lift is x=.560/1.7 = .329 so 1.85 ratio rockers would make youre lift 1.85*.329 = .608" lift... that's ALOT of lift... and would require good springs to handle it... (.560 was an example... dunno what lift cam you're going with)
so basically call patriot and see what they recommend... if they use fast ramps it's probably best to stick with stock ratio... also going higher ratio means you'll definetly want to clay to make sure you don't have to flycut the pistons
