Am I going to have issues :(
Old Jun 23, 2003 | 04:25 PM
99Z28Guy's Avatar
Default Am I going to have issues :(
I ordered a set of stage 2 heads (5.3L) and a cam (230/224 .575/.563 111LSA). After talking to a couple guys I know, I was told I will have piston to valve clearance issues! Is this true, because I'll try to change my order then!
Old Jun 23, 2003 | 04:33 PM
horist's Avatar
Default Re: Am I going to have issues :(
I doubt you'll have any p2v issues... still a good idea to clay it but I don't think you'll have a prob....
I'm running a 224/224 563/563 cam in my car (Stage 2 5.3L heads, no milling) and it was fine... I know others with the TR 230 cam and milled 5.7L heads and they aren't having a prbolem...
Old Jun 23, 2003 | 04:36 PM
Jason99T/A's Avatar
I can shift faster than you.
How much are milled off your 5.3l heads and what size valves are you using?
Old Jun 23, 2003 | 05:13 PM
99Z28Guy's Avatar
There is no milling whatsoever being done to the heads. Valves are 2.02"/1.57".
Old Jun 24, 2003 | 02:20 AM
Jason99T/A's Avatar
You shouldn't have any problems, but it is ALWAYS a good idea to check. We have run similar heads will .025" milled with no issues with that cam.
Old Jun 24, 2003 | 03:03 AM
99Z28Guy's Avatar
Thanks for the heads up Jason.
Old Jun 24, 2003 | 04:58 AM
u8dusst's Avatar
While we're on the subject of 5.3L heads, what will the compression be with a set of unmilled 5.3 heads?
Old Jun 24, 2003 | 06:44 AM
needmoremoney's Avatar
My first set of heads were 5.7's milled .030, and my cam was 228/236 .571.602, and when I clayed it, sure enough the valves hit. Set those 5.7 heads back, and recieved 5.3 heads milled only .005 for straightness, and now the car runs like a raped ape. Just to be safe, ALWAYS clay the piston first.
Old Jun 24, 2003 | 11:45 AM
VSGLS1's Avatar
Higher than stock LS1 heads. Around 10.8 give or take a tenth.
Old Jun 24, 2003 | 12:23 PM
Smoke_Ford's Avatar
Dont send your parts back. You shouldn't have that much clearence issure, so get a thicker head gasket.
