Quick Manifold bolt question
Old Dec 4, 2007 | 01:03 AM
Jarrett H's Avatar
Default Quick Manifold bolt question
Swapping an LS1 motor in my 7 and the engine didn't come with manifolds. I just needed to know what length and thread bolts i need to bolt the stock exhaust manifolds up.
Old Dec 4, 2007 | 01:09 AM
ssheets's Avatar
Well I happen to have one in my hand. The threads are 6mmx1.00 and the lentgh is 4.5 inches from the bolt end to the bottom face of the washer. They have a washer that is retained on them though and they look pretty OEMish, but the manifold is all O-ringed so an off the shel alternative may work?
Old Dec 4, 2007 | 05:03 AM
vettenuts's Avatar
That sounds like an intake bolt. The exhaust are 8X1.25 if I remember correctly. Can find out later at home or maybe someone else can confirm.
Old Dec 4, 2007 | 08:52 AM
ssheets's Avatar
Yep, I just saw manifold. I have an extra set as I just took off my stocks and will be using ARPs I'll measure them and get exact in awhile.
Old Dec 4, 2007 | 10:28 AM
Jarrett H's Avatar
4.5 inches did seem a little long.
Old Dec 4, 2007 | 10:51 AM
vettenuts's Avatar
Think I will let that one go by
Old Dec 4, 2007 | 10:55 AM
ssheets's Avatar
Exhaust manifold bolts are 8mm x 1.25 x 1.00 inch
Old Dec 4, 2007 | 11:11 AM
bczee's Avatar
that would be 8mm x 1.25mm x 24mm (if it is longer, then 30mm long)
