question on cam swap
Old Dec 4, 2007 | 07:38 AM
twinturbocutlass84's Avatar
Default question on cam swap
Planning on doing a cam swap from stock to Torquer v.3 and i was wondering if i will have enough piston to valve clearance for this cam with stock pistons and heads. Also was wondering what valve springs would be best for a cam of that size, thank you.
Old Dec 4, 2007 | 08:09 AM
socmguy's Avatar
Restricted User
You should have enough room with stock heads. Go with the PRC duals, they'll allow up to .650" lift.
Old Dec 4, 2007 | 09:26 AM
ls1leadfoot's Avatar
i have prc duals 650max
the v3 cam will be fine with those springs
