View Poll Results: What head fasteners are you using?
Stock type torque-to-yield
3
9.68%
ARP head bolts
9
29.03%
ARP head studs w/ hex nuts
8
25.81%
ARP head studs w/ 12pt nuts
11
35.48%
Voters: 31. You may not vote on this poll
Head fasteners of choice...
Old Dec 4, 2007 | 09:00 PM
Superado's Avatar
11 Second Truck Club
Default Head fasteners of choice...
Starting a new build...
Curious as to what everyone is using...
T2Y?...ARP bolts?...ARP studs?...
Did a search...lots of threads...lots of opinions...
thought I'd just do a poll instead...
Thanks!
Old Dec 4, 2007 | 09:33 PM
DONAIMIAN's Avatar
I say studs, I didn't vote because as long as its a stud your golden. 12pt v. hex all comes down to how often you plan to pull the heads.
Old Dec 4, 2007 | 10:33 PM
massls1guy's Avatar
ARP bolts here.
Old Dec 4, 2007 | 10:43 PM
SweeTbone's Avatar
ARP Head Studs with Hex Nuts here. Not that I even plan on pulling the heads, but cleaning out the bolts holes sucked. The clamping force is a little higher with the studs too.
Old Dec 4, 2007 | 11:23 PM
chuckyt1's Avatar
I used ARP bolts just because I thought it would be a little tight doing the studs in the car. I know others have done it without a problem.
Old Dec 4, 2007 | 11:37 PM
BerryWS6's Avatar
I didnt think having 12pt or 6pt mattered as far as clamping force, I think that is just personal choice.
but I vote studs
Old Dec 5, 2007 | 11:32 AM
Superado's Avatar
surprising results so far...only 12 votes however...
ARP bolts leading the poll...
Old Dec 5, 2007 | 04:21 PM
JPH's Avatar
JPH
ARP all the way. but depending on engine combo and horsepower output, that's when decision would be made to use bolts or studs.
Old Dec 6, 2007 | 06:55 AM
Superado's Avatar
thanks for the votes guys/gals...
how many of you voting ARP bolts are running FI?
Old Dec 6, 2007 | 07:30 AM
tonyt123blue's Avatar
what are you're plans just a head and can swap or F/I?
if your going na stock is fine.
Old Dec 6, 2007 | 09:55 AM
davered00ss's Avatar
Moderator
Studs are leading. 6 or 12 point, still studs.
Old Dec 6, 2007 | 10:09 AM
Superado's Avatar
I am currently FI...
I am building a forged LS1 to replace the stock 5.3L and keep the ProCharger set-up as well...
Old Dec 6, 2007 | 08:35 PM
Randy WS6's Avatar
12 point ARP head studs here ,No bolt holes to clean out. a paint in the ***.
Old Dec 7, 2007 | 09:44 AM
Superado's Avatar
LOL...you are correct sir!
stud votes are double the bolt votes...
Old Dec 7, 2007 | 11:47 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'll be running the studs, probably the 625 material. My engine is in as many pieces as it could be right now. I always thought 6 vs 12 point was preference. What's the advantage to one making them easier to remove than the other? Is it just the greater contact area using a 12 point socket on a 12 point nut?
Old Dec 7, 2007 | 03:43 PM
3.4camaro's Avatar
12-point spreads the force placed on the nut more than a 6-point. You are less likely to break something(probably the socket before an ARP nut).
Plus 12-points are prettier
