ms4 piston to valve
Old Dec 4, 2007 | 09:32 PM
6.0mcSS's Avatar
Default ms4 piston to valve
i have a lq4 bottom end with ls6 heads, texas speed magic stick 4 cam .649 in. .609 ex. with i have an piston to valve issue? Any help is appreciated
Old Dec 4, 2007 | 09:34 PM
ssheets's Avatar
Now I know why everyone always told me I'd find out when I measured it.
You can check similar installs and that should tell you, but in the end I bet you'll end up playing with an adjustable pushrod.
Old Dec 4, 2007 | 09:38 PM
6.0mcSS's Avatar
I cant find anyone that has this big a cam on a lq4 bottom end
Old Dec 4, 2007 | 10:31 PM
5.3LJimmy's Avatar
With what heads and gaskets? If our using stock heads and gaskets then yes it'll clear. Milled heads, larger intake valves, or thinner than stock gaskets will require valve reliefs. But as stated above, it's always best to check PTV for your particular setup.
