How Does This Setup/recipe Sound For Cam Only
im doing this setup
-comp cams 232 intake/236 exhaust 113+2 lsa
-patriot extreme spring set
-trick flow 7.400 hardened push rods
-melling select oil pump
-ls2 timing chain
-and gasket set
anything else that i might need trying to do the job in one weekend from friday afternoon to Sunday night , sounds good for cam only no heads?
Also, you will probably need either 7.425 or 7.450 length pushrods depending on which lobes you are getting XE-R or XFI. You may want to mic the base circle of the cam before choosing the pushrods.
Finally, I would highly recommend renting the install tools...they will save your a$$. The valvespring tool and the balancer install tool are worth their weight in gold!
