Comp Cam in from Rapid!
Old Dec 7, 2007 | 10:16 AM
C5LS6's Avatar
Default Comp Cam in from Rapid!
Got a Comp Cam installed and tuned by Mikey at Rapid Motorsports! Went with Comp Cam 228/232/113 0.588/0.591 WOW, what a difference! WAY MORE pull through out the ENTIRE RPM band! Air/fuel ratio is right on too! Mikey knows his stuff! I gained 43 rwhp and 34 rwt at peak. However, thats not the best news. At 3,500 rpms I gained 45 rwtq. At 6,500 rpms I gained 55 rwhp! What can I say, Mikey knows how to tune! Now at 420 rwhp and 397 rwtq.
Car and existing mods were: 01 C5 with LS6 motor, Vararam intake, AR LT headers, high flows, GHL catback.
Old Dec 7, 2007 | 10:22 AM
bigbill1's Avatar
Congrats.....is that with stock heads?
Old Dec 7, 2007 | 10:33 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Also, compared to a stock cam!?
Old Dec 7, 2007 | 10:54 AM
C5LS6's Avatar
Correct. All stock except the existing bolt ons stated above.
Old Dec 7, 2007 | 11:40 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Those are a some nice numbers for that cam and supporting bolt ons. Do you happen to have a graph?
Old Dec 7, 2007 | 02:11 PM
C5LS6's Avatar
I do, just not electronically yet.....
Old Dec 7, 2007 | 03:00 PM
ls1tork's Avatar
Great numbers. how's the idle (like stock or heavy lope), and drivability/low end torque? would it pass emissions? can you post a dyno graph? i really like those numbers for a cam only- i am trying to decide what mod to do for my ls1 GTO daily driver.
Old Dec 7, 2007 | 07:06 PM
cdoggy81's Avatar
^^^ me to...^^^
nice #'s btw!
Old Dec 7, 2007 | 07:22 PM
C5LS6's Avatar
Driveability is GREAT! Its all in the tune though. I mean its on a 113 so I have a little bit of lope which is what I wanted. You can tell I have a cam, but its not crazy at all. Low end torque is great too! at 2,500 rpms i gained 30 rwtq. Again though driveability has a lot to do with the tuner and Mike at Rapid Motorsports can tune!
Old Dec 11, 2007 | 09:32 AM
C5LS6's Avatar
here is the dyno sheet.
dynocam.pdf
Old Dec 12, 2007 | 09:39 AM
cdoggy81's Avatar
the power comes on & stays there all the way to the end, nice!
Old Dec 12, 2007 | 10:00 AM
CaptainSS1's Avatar
Yep. Mikey just put a fresh LS6 motor in my '01 SS. I was going to "leave it alone" but that idea didn't last long.
Dyno'ed about 415/412 thru a Moser 12 bolt with a heavy LS7 clutch.
Mikey knows his stuff and is trustworthy beyond measurement. Great guy to have on your side.
If he tells you something - take it to the bank.
Old Dec 12, 2007 | 10:36 AM
SLP Firehawk's Avatar
hey were is this mikey guy located i will need a tune on my car after i put the cam in it
Old Dec 12, 2007 | 08:30 PM
NOZR1's Avatar
Here is his site with the address... http://www.rapidmotorsports.com/
Old Dec 12, 2007 | 08:59 PM
DaveX's Avatar
Nice choice in cams.
