Best heads to get for under 1k?
Old Dec 9, 2007 | 11:04 PM
MJD's Avatar
MJD
If you're on a budget have your stock heads ported. You don't have to go to an LS6 head or aftermarket cast to get decent flow. Will be more cost effective because you don't have to buy a new cast and you won't have to worry about PVC.
Old Dec 9, 2007 | 11:12 PM
Vrbas's Avatar
Perhaps this
Old Dec 10, 2007 | 06:03 AM
CALL911's Avatar
Originally Posted by Vrbas
Perhaps this
Well, thats JUST over the budget, but would be piece of mind knowing I have a new set of LS6 heads. There are more than a few I am finding FS used though that seem to be a bit better for less. I may shop around a bit on the used market before I decide either way.
Anyone else have any input?
Old Dec 10, 2007 | 07:37 AM
njc.corp's Avatar
Cool
i aint made out of money either but-you say your budget is $1000.00 or under 1k
-why not wait a bit and get the extra $95.00 for the patriot's=
thats what i would do-like u said peace of mind knowing u got a set of ls6/243 cnc ported-
thats what i would be doing
everything brand new ready to go-
nothing wrong with second hand or light usage-but u never know-u never know-
whats a extra $95.00 for better performance and peace of mind-
Old Dec 10, 2007 | 11:24 AM
CALL911's Avatar
Thanks for the opinion, but at this point the way I am looking at it is; why spend $1100 on a new set of un-ported heads, when I can spend $750-$950 for a set of used fully ported ones that flow better?
Granted they won't be new, but that is the side I am leaning towards as of now.
Old Dec 10, 2007 | 11:31 AM
sroach20's Avatar
any heads will be used no matter what after the car is started.
Old Dec 10, 2007 | 01:01 PM
Thorny's Avatar
The $1100 heads are ported w/ dual valve springs and Ti retainers, you can buy them unported for $425 assembled w/ stock parts.
Old Dec 10, 2007 | 03:47 PM
CALL911's Avatar
I understand this. But the point I am making is that I can get a much better quality, and flowing set of heads used for the same price if not less than the $1100 new ones.
Old Dec 10, 2007 | 03:58 PM
Vrbas's Avatar
It's up to you man... but you said it yourself --> "peace of mind"
Old Dec 10, 2007 | 04:05 PM
Thorny's Avatar
You're not going to find high-end used heads for under $1000. Even the Patriot heads are bringing around $700, TFS and AFR heads are considerably higher. The only used heads you're going to find for under $1k are going to be ported stock castings or maybe a set of unported aftermarket castings.
I guess I don't understand how you don't consider this head high quality, it's one of the best ported OEM castings on the market. You don't get into better flow numbers until you get into the much more expensive castings.
Old Dec 10, 2007 | 04:11 PM
Bad Blue WS6's Avatar
i dont get it either,,i must be missing something somewhere....
Old Dec 10, 2007 | 04:12 PM
  #32
N4cer's Avatar
Depends. Have you guys been checking these heads on independent flowbenches, or do you just believe the advertising you are spoon fed from a company?
  #33
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Definately look at the PRC Stage 1 LS6 heads. At 1049 they are right in line price wise & they make awesome power! You can even checkout GM High Tech magazine where a ms4 & stage 1s made over 550flywheel horsepower! Power like that makes these heads the best valve by far compared to similar priced competition!
Jason
Texas Speed
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Dec 10, 2007 | 04:16 PM
  #34
CALL911's Avatar
You're not going to find high-end used heads for under $1000...
I already have
Old Dec 10, 2007 | 04:21 PM
  #35
COD02SS's Avatar
Obviously used will be the best deals to have, but I am having a hard time even finding used heads for under $1,000.
What would be the cheepest heads to get that would be an upgrade from LS1 heads? I am guessing just LS6 heads, but I have yet to see any.
Why even do heads if you're going to cheap out? Look for some used PRC 5.3L's
Old Dec 10, 2007 | 04:25 PM
  #36
Thorny's Avatar
I already have
What and where?
Old Dec 10, 2007 | 04:55 PM
  #37
CALL911's Avatar
Well if you call Dart or AFR ported heads "Cheaping out" then yeah I guess I am considering that (lol).
As of now I'd like to keep where I am finding these quiet as they do seem to be smokin deals (possibly too good to be true).
The other thing that I need to find out is what needs or will for sure require the pistons to be flycut? This doesn't need to be done with say a set of stock heads, but depending on the clearances some aftermarket heads will be a must, and its an additional $400+ cost I am trying to avoid if neccisary, and may be key in what heads I do end up purchasing.
Old Dec 10, 2007 | 05:22 PM
  #38
Vrbas's Avatar
Therein lies the problem. Be careful.
Old Dec 10, 2007 | 05:32 PM
  #39
CALL911's Avatar
And that is always a possibility, but I do have faith that most sellers are honest, and their trader rating reflects how they do buisness accuratly.
Old Dec 10, 2007 | 06:12 PM
  #40
N4cer's Avatar
Well, I'll ask:
If you are one of the guys offering a set of Darts or AFRs for that cheap, let me know if CALL911 doesn't buy. I am interested in a large runner head such as these.
