What else?
Go with the LSX engine then, if you have unlimited amount of money. The Lsx can hold up tp 2500hp, so it has been stated.
With my cam i dynoed in at 380/375 at the wheels.
hahaha This thread needs to be locked and forgotten
um... not trying to argue or put you on the spot, But there is an "LSX" engine, its an iron block. I know the other LS engines maybe called that too, but they mention them as "LSx" engines, with a little "x", not the big "X".
I have taught my student for the day!
but the problem is that alot of things you would do now...to get power. would end up getting discarded due to them being the wrong way to build a motor for 1000hp.
only way to make that power is basically forced induction.
that means any heads you buy now...that would help on the stock shortblock (or even a small stroker) are gonna boost compression. which is exactly the OPPOSITE of what you want to do for FI.
so you'll be buying new heads.
also any heads that will benefit a stock cube motor will not be able to keep up with a big cube motor. yet another reason you'll be buying new heads down the road.
even if you get a new block now...for a high hp application..with FI...you'd want dished pistons to keep the compression down. which would kill your n/a performance. so down the road you'd need to do a piston swap.
also you're kindda contradicting yourself. you want power, but you're worried about breaking the motor. well logic would say to rebuild the motor for your shorter term goals. or else put the heads on it now and wait till it blows...then do it.
you can either be pro-active or pro-prayer....build it before it blows or built it up and pray it doesn't blow for a while.
next problem is gonna be things like drivetrain, suspension, chassis.....all will need to be address. probably need to be addressed now since you're already making decent power.
the stock auto trans is not well known for holding 450rwhp
the stock 10bolt rear is WELL known for barely holding stock power levels.
under high power, the frame (uni-body) flexes enough to ripple the body, so SFC or a cage is needed.
i can go on...and on...
