Vaccum leaks! Where-to and how-to.
I think i have a vaccum leak somewhere, I can hear what sounds like it, but for the life of me i cant find it. Ive done the parts cleaner spray trick, and the idle gets a little messy, but it was only because it got sucked through the intake.
What are the normal problem spots or other ways i can find the leak/s?
Thanks!!
areas to check..:
MAP
Vacuum lines (Purge valve, HVAC and Brake booster lines.)
injectors o-ring/fuel rai/intake
Intake to Head seals
Throttle body
PCV
EGR port
Good Hunting.. let us know if you find a leak or it turns out to be something else.
Actually buying a mechanics stethescope is a pretty valuable tool because it can allow you to listen to bearings while the engine is running (with the transducer attached to the hose) and use it as an acoustical tube too!
Steve
Johnny
Steve
Steve
I'll start with the list, does anyone have vaccum line diagrams? Also, where is the MAP sensor located exactly?
areas to check..:
MAP
Throttle body
PCV
EGR port
Thanks!
Steve
