Stage 2.5 5.3 L Heads With Ms3 Cam For Nitrous Set Up Are This Good Heads And Cam
![Arrow](https://ls1tech.com/forums/images/icons/icon2.gif)
I CALLED TSP TO SEE WHAT THEY RECCOMENDED FOR A NITROUS SET UP WITH STOCK BOTTOM END MY CAR MODS ARE IN MY SIG AND I AM SPRAYING150+ WITH NITRO DAVES PLATE SYSTEM AND THEY TOLD ME THE 2.5 5.3 L HEADS WITH THE MS3 CAM i MIGHT SOUND STUPID BUT NEVER HEARD ABOUT THESE HEADS ANY INFO WILL BE GREAT THANKS WHAT DO YOU GUYS THINK ABOUT THIS SET UP I WANT THE MOST POWER AND I DO NOT CARE ABOUT EVERYDAY DRIVING OR GAS.
HAS ANY OF YOU HAD THIS HEADS OR CAM IN YOUR CAR IN THE PAST AND HOW DID IT WORK ANY NUMBERS WILL BE GREAT THANKS.
Sounds good I will look him up and give him a call about the custom grind cam. About the heads do you recommend those heads or do you think the patriot stage 2 heads are better?for this set up. I called Patriot perf they recommended the stage 2 heads with a custom grind cam. which set up do you think will be better?
they arent that much better, they just cost more. if you want to save money go withthe patriots, if you want to blow money and get good performance, go with the AFR's. The 5.3liter PRC's will give you more compression, but the patriots also have the 5.3's. My opinion they both flow pretty close to themselves. My advice to you is to look up the numbers yourself and figure out what you want.
