crank and piston problem help!!
Old Dec 13, 2007 | 06:21 PM
blackdrag on's Avatar
Alright man thank you so much, it definitely help. Im gonna work on it tonight and we'll see what turns out. LOL "turns" out
Old Dec 13, 2007 | 06:23 PM
chriswtx's Avatar
Good luck...
Old Dec 13, 2007 | 11:41 PM
ArKay99's Avatar
Did you put gaskets on the heads?
Old Dec 14, 2007 | 05:35 AM
chopper's Avatar
Are the rocker arms and pushrods installed?
If so, remove them and Your problems should be over.
If not, dis-regard My post.
Old Dec 14, 2007 | 08:37 AM
383jake's Avatar
befor you pull it apart... time it and conect the timing chain after its degreed. try and rotate the engine over SLOWLY. there is a good chance you may have had the cam just sitting in ther at the wrong degree. if anything is hitting the cam, it would be the connecting rod endcap. check the clearance to all the lobes, you should have a minimum of about .020. may have to grind the endcap, and depending on how much you take off you may have to get the rotating assymbly balanced again.
