good cam?
Old Dec 13, 2007 | 11:59 PM
LS1>Imports's Avatar
Default good cam?
does this sound like a good cam for a daily driver
Thunder Racing Custom Camshaft
"227 xTReme" - 227/227 .639/.639 116 LSA
Old Dec 14, 2007 | 12:13 AM
bczee's Avatar
Duration sound ok, LSA would be good for the idle, but the lift maybe a bit much, springs would be taking a beating.
Old Dec 14, 2007 | 08:31 AM
1999ssls1's Avatar
Thats a good forced induction cam. IMO You wouldnt be able to hear it really with a 116 lsa.
Old Dec 15, 2007 | 12:46 PM
PREDATOR-Z's Avatar
Good Stealth Cam, with the proper springs like Patriot extreme duals or shimmed Comp 921s there would be no issues. That cam will rev high so I would also think about beefing up your rod bolts.
I read in your sig STS, I assume Turbo. You do not need that much lift for FI. Speak to Patrick G, he is affiliated with Thunder and can spec you a custom cam just for your needs.
