Help new engine install - how will the computer know where..
Old Jan 2, 2003 | 05:51 PM
Godzilla's Avatar
Default Help new engine install - how will the computer know where..
When I swap out the engine what will I need to do to as far as the reluctor sensor?
How will the PCM know the new motor is at TDC?
thanks
Old Jan 2, 2003 | 06:54 PM
MyLS1Hauls's Avatar
Default Re: Help new engine install - how will the computer know where..
It uses the cam and crank position sensors to calculate TDC. You should do a Crankshaft Position Sensor learn w/ a Tech 2 though, after the engine swap.
Brad
Old Jan 2, 2003 | 07:10 PM
C_Williams's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MyLS1Hauls:
<strong> It uses the cam and crank position sensors to calculate TDC. You should do a Crankshaft Position Sensor learn w/ a Tech 2 though, after the engine swap.
Brad </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey, I'm facing the same scenerio - will the Tech II learn session mess with my LS1 edit file?
