Random miss fire need HELP
Old Dec 15, 2007 | 05:39 PM
eallanboggs's Avatar
As long as both O2s are disconnected all bets are off. You're going to stay in open loop. Even after your ECT comes up you still can't control your AFR. You can leave the rears out for now if you want. You're going to still get the rear DTC, but you MUST get the front ones working. Then you can start troubleshooting the P0300. If you hook up the front O2s the random misfires might stop. You'll never know until you hook them up. If not, you have to look for something in common to ALL 8 cylinders since it is random. The ECM can narrow it down if one particular cylinder stands out, but yours is all over the place. Start thinking about what sensors are common to all 8. Connect the fronts and work from there.
Old Dec 15, 2007 | 06:12 PM
8a8mfh's Avatar
One bent intake valve will blow pressure into the intake enough to screw with the MAP, and it may cause random misfires.
Old Dec 15, 2007 | 07:13 PM
miller456's Avatar
Thank you for your help guys I will try it when we go back and update everyone if it solves the problem or not.
