patriot performance heads?
Old Dec 15, 2007 | 05:39 PM
Disturbed Bird's Avatar
Default patriot performance heads?
do i need a stage 2 or 3 head?
i have stock ls6 compression, a 240/244 112 lsa cam, a ported 90 fast.
Old Dec 15, 2007 | 11:22 PM
anyone?
Old Dec 16, 2007 | 12:08 AM
PREDATOR-Z's Avatar
Stage 2 because you are stock cubes, you prolly will need flycut.
If not want to flycut, then stage 1 (stock valves)
Old Dec 16, 2007 | 12:19 AM
what causes me to have to fly cut?
Old Dec 16, 2007 | 01:20 AM
Vrbas's Avatar
PTV clearance issues.
FYI, the picture in your sig is my background (the Phoenix bird).
Old Dec 16, 2007 | 10:34 AM
sedanman's Avatar
I too have been looking at patriot heads for my stock shortblock LS1, I have a LS6 intake, MS3 cam and Longtubes and wanted to swap heads and I was thinking that I read that you could use Stage 2 heads with the stock pistons without fly cutting usually? I know the cam is going to be what determines PTV clearance but does anyone know if this will fit?
Old Dec 16, 2007 | 11:40 AM
what if i go with a thick head gasket. would i need flycutting then? iv had this cam in for a year now with ls6 heads and no problems. do you think ill need to fly cut with a stage 2?
Old Dec 16, 2007 | 03:23 PM
ringram's Avatar
How much clearance have you got now with the 2" valves?
If you cant answer that, then nobody can answer if you need to cut with the larger valve of the stg 2.
Old Dec 16, 2007 | 03:51 PM
Asmodeus's Avatar
Not unless the valves are sunk, the bigger ones will not clear an MS3. You can go with ported stock valve unmilled LS6 heads.
Old Dec 16, 2007 | 03:58 PM
RiskyZ28's Avatar
guess ill need to re think things. i was thinking of doing the same setup with the stage 2
Old Dec 16, 2007 | 04:48 PM
dont know.
Old Dec 16, 2007 | 04:54 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Give Gunnar at Patriot a call and discuss your questions directly. He will steer you in the right direction.
Steve
Old Dec 16, 2007 | 04:57 PM
does ptv=piston to valve Clarence?
should i get the 2.055 intake valve or the 2.02?
Old Dec 16, 2007 | 05:23 PM
Asmodeus's Avatar
no, ptv means piston to valve clearance.
You got the biggest cam you could fit under stock heads. Stock heads also mean stock valves. If you go any bigger than a stock valve, you're going to have issues. It's really simple to understand. If you want a bigger valve than a stock valve, YOU WILL HAVE TO FLYCUT. You can't get either of those valves.
Old Dec 16, 2007 | 07:27 PM
thanks for the advice but i kind of asked if that is what it meant. lol. so then i should get the 2.055 valves since im going to have to fly cut.
oh i forgot to mention that its a complete ls6 engine so i dont know if that changes anything. do they have valve reliefs in the pistons?
Old Dec 16, 2007 | 08:04 PM
Asmodeus's Avatar
No, the LS1 and LS6 shortblocks are exactly same, except the LS6 block has better bay to bay breathing.
Make sure the 2.055 valve fits in a 3.9 bore, I think that valve is right at the edge of being too shrouded inside the stock bore, if it fits at all.
