Stock Injectors Enough?
Old Dec 18, 2007 | 03:29 AM
tee-boy's Avatar
Default Stock Injectors Enough?
Would I need bigger injectors on a 98 with a 228/230 cam and a set of AFR 205's with FAST 90?
Old Dec 18, 2007 | 03:35 AM
bryan04h's Avatar
your stock injectors should be good for the 450's and up a lil...might want to upgrade the fuel pump tho
Old Dec 18, 2007 | 04:39 AM
BlackScreaminMachine's Avatar
Internet Mechanic
228/230, can we say VRx4!?
As for the injectors, its always good to run the calculator, and if I recall the 98's in stock form had the lowest "rated" injectors.
Old Dec 18, 2007 | 06:08 AM
Spartan's Avatar
Only way to tell is datalog via live monitoring.
Best way to increase or maintain injector capacity is having an adjustable fuel pressure regulator. Only after that can you make the decision to change or not.
Old Dec 18, 2007 | 09:16 AM
RZRSEDGE's Avatar
I think the 98 had the 28.8 injectors like the 01-02. You have a considerable amount of money tied up in that setup, I'd go ahead and upgrade to at least the SVO red-tops. Just my 2 cents worth tho.
Old Dec 18, 2007 | 10:55 AM
tee-boy's Avatar
Well I guess just another reason not to wait for a tune. I imagine, a tune with A/F will help identify the answer.
Old Dec 18, 2007 | 10:58 AM
ONEBADWS6's Avatar
Get the SVO 30lbs
Old Dec 18, 2007 | 11:20 AM
JPH's Avatar
JPH
i say 107-112% duty cycle at WOT. U will need to change them.
Old Dec 18, 2007 | 11:49 AM
lsheaven's Avatar
98'a had the highest rated injectors, not the lowest
98- 28lbs
99+ -26lbs
Old Dec 18, 2007 | 11:54 AM
seawolf18's Avatar
When I did my swap, I put in a set of SVO red top 30lbs. Since the fuel pressure is higher on the camaro, they end up being in the 36lb range.
Old Dec 18, 2007 | 11:56 AM
98Camarod's Avatar
With just my cam, I was at 115%+ IDC, not good. You should get atleast the SVO red tops.
Old Dec 18, 2007 | 06:59 PM
black01_WS6's Avatar
98- 28lbs
99+ -26lbs
Not true- 01 and 02's had the 28's, Never heard that the 98's had them as well.
I am at 97% duty right now and you would be over my power, so you would definatly need to change them out.
Old Dec 19, 2007 | 05:39 AM
tee-boy's Avatar
Default fff
98's did have the larged injectors along with the larger cam.f
Old Dec 19, 2007 | 10:51 AM
dmart's Avatar
Man, I was 95% with just bolt-ons, though I have a 2000 with the slightly smaller injectors.
Old Dec 19, 2007 | 11:47 AM
lilbuddy1587's Avatar
+1
Better to be safe than sorry.
I'm running the red tops with my current stroker combo and all is well.
Old Dec 19, 2007 | 12:37 PM
3rdgentug's Avatar
like said befor at least get the 30# ford red tops
flow matched if you can afford them
Old Dec 21, 2007 | 05:48 PM
418redz28's Avatar
better to be safe then sorry. id go with the svo red tops
